PreferLinux
- Dec 29, 2010
- 420
- 0
- 0
Thanks for this. It was very clarifying.
I got some baseline temperature data and took my first stab at overclocking this thing. Ultimately, I want to evaluate the value of the Hyper 212, so I did all of this with the Intel stock heatsink/fan.
Here's how I measured temperature and voltage:
CPU temperature: After 10 minutes of Linx 0.6.4.0 & Prime95 25.11.1.0 Blend & Super pi 1.1e 32M / Degrees C as reported by ASRock eXtreme Tuner
CPU voltage: After 10 minutes of Linx 0.6.4.0 & Prime95 25.11.1.0 Blend & Super pi 1.1e 32M / Vcore as reported by ASRock eXtreme Tuner
GPU temperature: After 10 minutes of FurMark 1.6.0 / Stability test / Xtreme burning mode / Full screen / 1680 x 1050 / MSAA None / Degrees C as reported by FurMark
Test 1
Settings: default
CPU temperature: 60 degrees C
GPU temperature: 84 degrees C
CPU voltage 1.216 (I didn't touch this in bios, it automatically selected it)
Test 2
Settings: default, except CPU max ratio (what ASRock calls the multiplier) = 48
CPU Voltage: 1.354 (I didn't touch this in bios, it automatically selected it)
CPU temperature: 94 degrees C (terrifying!)
It crashed 9 minutes into testing--I've heard the PC restarts itself if the diode on the chip reads 100 degrees C.
Test 3
Settings: default, except CPU max ratio = 48 & speed step disabled
It crashed while windows was booting.
Test 4
Settings: default, except CPU max ratio = 44 & speed step disabled
10 minutes of stress testing succeeded. Though, I don't plan to run it like this given the outrageous temperature.
Questions
One thing I found puzzling was that even with speed step off, when I set the multiplier to 44 and 48 in BIOS, the CPU throttled down to multiplier = 37 when running the stress tests. Why is this and how can I stop it?
I find the high temperatures surprising given the voltage. I wonder if I screwed up the HSF install--though I thought that if the four plastic clips (the clear pieces on the bottom right picture on http://www.geekwithlaptop.com/intel-redesigns-heatsink-for-sandy-bridge) snapped in to the holes on the motherboard, then I was golden. Any ideas as to why this might be?
You have the ASRock Extreme4 too? I've been playing with it all afternoon and I can give you my feedback.....
1) GET the Hyper 212+. I paid $15 AR for it.
2) for your throttling issue, I had the same problem. I saw in Anandtech review of the mobo what is the solution I believe. You need to change the Long Duration Power Limit higher than the 95W that the mobo starts with. I changed mine to 110W, and haven't had any throttling since. I've seen others who have put it to 255 (highest value I assume) but I figured I might as well keep some safeguards in place rather than just take out the seatbelts and airbags completely.
So compare my 44x to yours - temps MUCH better and if I were you, I'd do your own voltage as it seems your mobo is being pretty volty on AUTO.
3) I'm kinda liking this OFFSET voltage setting rather than FIXED. Fixed means it stays at the spec amount all the time. Offset retains the throttle down functions, so when it idles it heads back to 16x and the voltage is around 0.95+/- for me. I'm trying to design a moderate OC that I can "set it and forget it" so I like minimizing the voltages. I am not gonna be a "here's my screenshot of 5.3ghz" ooops I fried my CPU after 2 months kinda guy.
Here are my OC results and temps.....temps WAY better than what your stock is getting.....
-I am 1.5 hours into the following Prime test - 44x multiplier, 1.26V, and temps are hovering around 58-61C and HWMonitor shows the max on one core hit 65C at some point in the past 1.5 hours.
Also I figured out that ASRock Load Line Calibration is Level 5 = none, while Level 1 is Lots! I choose to keep LLC off - seems there is debate about LLC's benefits vs risks.
Also I trimmed CPU PLL to 1.79 (board defaulted to 1.83) and it appears others are trimming more to the 1.75ish area. Not sure if it helps any, but didn't seem to hurt, and in general I guess "lower voltage at a given speed" is fine as long as its stable.
OP: Temps are waaaaay too high, and voltage is too high for a 4.4 GHz OC. You should need no more than 1.32V for 4.4V, and possibly less. Forget the offset and go with realistic base values and a realistic speed level and make that work first. Look at my system, which is very similar and passes Prime overnight tests and LinPack. It's at 1.32V.
Make sure you're not overvolting the RAM! Set the PLL to 1.9V max, PLC to Ultra settings or higher in BIOS. I can post more details tomorrow if requested, time to hit the rack.
Why put your power limit up to 500? Just wondering. I just put it to 110 like Anand did and I haven't seen the throttling. I guess I need to think more about what its doing - but I figured if its some form of safety belt, I might as well keep in in place (just loosen it).
I think people like LLC because then they don't see any Vdroop - so if you're fixing a voltage at 1.25 then under load it will stay there. I'm not quite convinced because of the microspikes - if your mobo is basically stepping on the voltage gas once the load comes, I can't see how it can't overvolt for a split second once the load is released until it figures out that it needs to step off the voltage. I guess lots of people say "well it never hurt MY chip" but then again, I doubt most people end up with a failed chip so they probably would never know if they're doing any damage.
Blitz Krieger said:LLC is intended to correct that drop, known as vDroop, you've seen in the power delivered to your CPU. vDroop exists because when your CPU goes from full power drawing loads of Amps to a sudden idle state, it takes the power delivery system a few micro seconds to reduce the flow, so for an instant your CPU is being over-supplied with power. The drooping assures that this spike will not go above the originally intended voltage set in BIOS. With LLC enabled, this effect is negated, and your CPU is supplied closer to the intended voltage at load, but when that load is removed the resulting spike in momentary over-power goes above the intended voltage set in the BIOS. For example say your CPU needs 1.3625v in BIOS with LLC off to be stable. At load it might draw, say, 1.279V so that when the load is removed it might spike to say, 1.3614v.. within spec set in the BIOS. With LLC enabled only BIOS 1.3125v might be needed to be stable, yielding 1.29v load, thus allowing a lower overall settings for general idle/load conditions; but when load suddenly drops to zero the resulting spike might be say 1.44v, taking the system over the spec voltage of 1.3125v and over the non-LLC required voltage of 1.3625v for a few micro-seconds.
**Please note all of the above numbers are fictional, but the concept is accurate**
The debate about LLC is due to the lack of information regarding the length, severity, and overall effect the spikes mentioned above. My advice is this: LLC is a fine tool for the bleeding edge, imformed carefull use can have great benefits. Use it like you would a razor, cautiously, and it may prove to be just the tool for the job!
Blitz Krieger said:Stock CPU cooling = Fail, Aftermarket = Win
Blitz Krieger said:at least decrease voltage until you reach instability once you have your core speed to find the min required voltage and run 1-2 steps above it as needed.
This was a really helpful discussion. One of my main interests in fiddling with over-clocking is to learn more about electricity and temperature and this was very informative.Blitz Krieger said:On the relationship between Volts, Speed, and Temps:
LiuKangBakinPie said:
Here is a summary of the stable iterations I've done so far.
Frequency / Vcore / Tcore / Heat-sink / BIOS settings
3300 Mhz / 1.216V / 60 C / Intel stock / Default
4400 Mhz / 1.354V / 94 C / Intel stock / Default
4300 Mhz / 1.200V / 66 C / Intel stock / Power limits = 500W
4500 Mhz / 1.275V / 80 C / Intel stock / Power limits = 500W
4700 Mhz / 1.350V / 66 C / Hyper 212 / Power limits = 500W
It's amazing to me what an improvement the Hyper 212 is over the Intel stock cooler. To be running .075 Vcore higher yet 14 degrees C cooler is remarkable.
Given the constraints I set at the outset, I think I'm stuck at 4.7 Ghz. While I'm well within my temperature threshold (66 vs. 80 degrees C), I've hit the voltage wall that I'm comfortable with (1.35 Vcore).
The next line of investigation is going to be geared towards minimizing temperature. I will be looking at what fan types and arrangements strike a good balance between low temperature and high noise. I may also fiddle with some of the more exotic cooling methods.
After that, I plan to branch out into GPU over-clocking and CPU memory over-clocking.
