Please help!!!
amol
11,680
argh, accidently pushed enter
wait for my real post :p
edit : okay, real post right below this one
amol
11,680
i restarted windows on my desktop and i get this error message :
Windows could not start because of an error in the software.
Please report this problem as :
load needed DLLs for kernel.
Please contact your support person to report this problem.
help! what do i do? i have a lot of stuff on my C:\ that i havn't gotten a chance to backup yet
Mar 19, 2003
18,289
Originally posted by: Amol
Originally posted by: biostud
put in WinXP install CD repair installation
i dont get what youre saying
You don't know what a repair install is? :confused:
Basically you boot from the CD just as if you were going to install a fresh copy of XP, tell it to install to the same drive, and it will ask you if you want to repair the current installation (once it finds it). This basically just replaces all the system files (and as such, you may have to upgrade to SP2 again, etc.)
amol
11,680
Originally posted by: quakefiend420
can you boot in safe mode?
no
Boot from WinXP install CD
choose repair installation :)
it wont erase my other files, will it?
sorry, im just really cautious when it comes to this stuff, i had 3GB of info deleted when i did something similar on my laptop
luckily, most of it was backed up onto CD and the rest i just downloaded or installed again . . .
Mar 19, 2003
18,289
no
Just be careful, and don't let Setup proceed with anything before you're 100% sure what it's doing. :p
A repair install will leave everything intact (documents, even programs, etc.) - it just replaces system files with the ones on the CD.
amol
11,680
no
okay, so i'll just make sure not to click "yes" when it says, "ready to reformat" :p
Aug 26, 2004
14,685
no
yeah, i would give that a try and report back
amol
11,680
no
where/when would i choose repair installation? i don't see it anywhere yet . . .
Mar 19, 2003
18,289
no
Like I said, I'm pretty sure you go about it as if you're going to do just a normal Windows install onto the drive...at which point it'll scan and find an already existing Windows install, and it'll ask you if you want to repair it. (Hint: you do ;))
amol
11,680
ahh okay, i did that and now it says :
Setup cannot create the folder:
\WINDOWS\mui
Setup cannot continue until the folder is created.
Mar 19, 2003
18,289
\WINDOWS\mui
:confused:
Never heard of that one before.
If it's not something simple like the drive is full or something...then I have no idea what to make of that, lol
biostud
19,931
7,039
is your drive NTFS formatted?
If it is I don't see another solution than trying to install windows on another partition, or another harddrive with the current unplugged to be 100% safe.
If it's FAT32 get a win98r2 bootdisc and copy the stuff to another partition
amol
11,680
\WINDOWS\mui
:confused:
drive can't be full, it's a 250GB drive with about 70GB used
amol
11,680
it is NTFS
biostud
19,931
7,039
it is NTFS
can you move the drive to another computer to get the data off? (not as the boot disc obviously)
amol
11,680
it is NTFS
not one of my computers . . .
one is a laptop, and the other is a 5 year old machine that has a 100WATT PSU running a cd rom, hard drive, floppy, motherboard, cpu
i'll have to find a friend who has a computer that they can lend me for a while
if i buy another HDD, install that, put Windows XP on it, can i transfer the files that way?
biostud
19,931
7,039
it is NTFS
yes, if you don't have some encryption one your NTFS drive, in which case it doesn't work to put it in another computer either. See the thread in OS if you have.
amol
11,680
it is NTFS
i dont think i encrypted my NTFS drive . . . . . . . .
biostud
19,931
7,039
Then lending a computer, a fresh install on another partition or harddrive is the way to go AFAIK. Another harddrive with current unplugged is the safest way to ensure nothing goes wrong, but you can also install on another partition if you have one.
amol
11,680
no, i only made one partition when i formatted the drive . . .
i guess i'll order a drive from Outpost.com in the morning, there are a few good rebates happening ($70 for 200GB) . . . use that, install XP, transfer all the files
then reformat this 250GB drive i have right now and make partitions . . . what do you think i should make the partitions as, just as to avoid this in the future . . .
i think i'll then sell the drive i buy tomorrow on FS/FT or something
