Just got a new DLP trying to put it in a friends house. Door way is a little smaller than he thought. Is there a way I can take off the rear cabinet to just reduce the size or even the front screen?
Would putting it onto its side be ok? Thay idea was thrown out but i didnt want to because I thought doing that would break somthing inside. Any specific precautions? We were able to get it in the house bit the room he wants it in is at the end of a hallway which does not allow for any great amount of turning room.
Ok so we were able to turn it on it's side onto a few blankets. Got it moved in and everything turned on ok and picture still seems good as well. Thank you all very much for your help I really appreciate it.
