Only put on the folder for WinXP and leave the other folders off of the floppy.Originally posted by: xodius
ok that link...it took me to a download and the SATA it too big for a floppy. I tried to install on 2 and it will not work either. URGH. I am ready to just shoot my computer.
If you do that route, then one modification:My old HD is a ATA, Seagate 160 GB....it runs slow though. If I dr5op it in, it will be reformated...rightt? SO then I should not have to worry about any viruses or anything like that correct??
Not without some third-party software, but it wouldn't be the end of the world if the 160GB drive is your boot drive either.Then I could install all this other crap for SATA and eventually pull the ATA...right??
I thought that too, but the files are an install.exe and *.cab files. Not what you would expect, the files install the RAID drivers into an existing Windows setup. Very, very dumb setup. Looks like the only usuable SATA files are on the mb disk.Originally posted by: mechBgon
Ooops!Originally posted by: Woody419
If you're having him use the SI drivers then we better get him to plug the drive into the SI controller. I had him on the nVidia controller since it's not jammed on to the overcrowded PCI bus.Originally posted by: Woody419
Got-em. Inside the Si3112 folder is ANOTHER Si3112 folder WITH THE DRIVERS!
What the heck, just copy everything except the DriverLanuageMap.xml to a floppy and you are good to go.
Hehe... now you see why I don't have a quick simple SATA-installation section in my Newbie Guide, huh?Originally posted by: Boztech
I'll say one thing, this is definitely turning me off on the Gigabyte boards I was looking at for my nF4 system.![]()
Hehe... now you see why I don't have a quick simple SATA-installation section in my Newbie Guide, huh?*whaps Gigabyte upside the head with a floppy cable*
I promise to add that much, yeah... maybe later this week I'll have a bit of free time to tear open my work rig and shoot some photos of my new SATA drive, cable and mobo fittingsOriginally posted by: Boztech
Well you could show the physical installation of the drive without having to go into the software install side of things.
After all it is a computer assembly guide, not an O/S installation guide.
Those drivers are for the Silicon Image SATA controller, which controls only the SATA jacks at the bottom edge of the board. I wouldn't use it except as a last resort since it shares the PCI bus with about eleventeen other bandwidth-sucking devices, I'd use the upper SATA jacks that are operated by the nVidia controller. That means having the nVidia drivers, not the SI 3112 drivers.I installed the 3112 and the 3112r but they didnt work...I am clueless.
