Three week ago i through i have a not working Duron 600 and went out to buy a Duron 1.2Ghz. but imfact it was not the cpu's problem but the power supply. So now i have a Duron 1.2 Ghz in hand and why not use it??
Most of my time i use my PC to surf arounf the net and therefore does not require high CPU resources. But recently i came aross a site which is very interesting and want to download it, so i usewebzip to do. But the site was too large and contains about 18900 links... now... after a few min of downloading, it crashed!!
WEb zip was known to be unstable, but this is not normal crash. As my monitor turn off to standby mode, my lan card LED went off, and my CD rom and CDR had there front LED on even with no disk in it!!
What is going on??? I have try it agin with webzip again a few times after and the same thing happen EVERY time!!!
Then i am thinking could it be CPU overheat?? So i run 3DMark2001 ( WinXP ) , and after a few min, it did the same again............
Could it be CPU over heat?? i use Hmonitor to check, and sometimes it goes up to 50- 56 degrees, is this acceptable?? Or if it is not CPU overheating, what could it be??
Please help.............
