fishmonger12
- Sep 14, 2004
- 759
- 0
- 0
Originally posted by: StatsManD
Originally posted by: Vertimus
Nobody's going to solve your problem if you don't state the problem correctly. When c=0, the area of the shaded region is only 1/2 if you restrict yourself to the first quardrant, which you didn't specify.
My bad, forgot that little tidbit. Yes we must also assume x>=0 and y>=0.
Someone on ATOT, has to have a high level undeder standing of math. Where are the math, physics and engineering Ph.D crew.
The case when c=0 is trivial.
Now prove as c goes to 1 the shaded area decreases monotonically. then prove this statement still holds true when we interchange x and y.
That's pretty easy too. Assume the area doesn't decrease monotonically as c increases. Find a contradiction.
