Stick w/ Tyan.. Get a single Opteron 246 $460 and 2 - 1gig memory sticks and the Thunder K8W
The K8w has 64bit/133mhz slots which the tiger doesn't have..
Also get a power single rail psu, dual rail psu's are not good for dual cpu mobo's..
Getting the 246 now w/ 2 gigs will probably be all you really need. Later you can get another 246 w/ 2 gigs of memory.
It's better to use larger dimms , rather than populate w/ smaller dimms.
Right now I have a customer w/ a poweredge that has dual 700's & 2 gigs of memory & raid5 scsi.
They are running an enterprise database "Unify", firewall, samba, squid.
They can search 150000 records/second. It takes 3 seconds to bring up 1300 out of 1.86 million.
This is on an old dell server.
As far as hd is concern, platter speed in not everything. A Atlas 10k4 will kill a 74gig raptor in a server environment.
I'd get a LSI320-2 w/ some 36g scsi hd's.
This will last you a very long time. Also getting 1 fast processor gives you the upgradablity in the future to add a second w/ addl. memory.
Personally I'd triple check the motherboard recomended memory modules and go w/ that..
Regards,
Jose
