MrMPFR
- Aug 9, 2025
- 246
- 456
- 96
YehBut not really much over the PS5 Pro.
I think the GPU clock will be in the 2.5 Ghz range.
If true Sony gonna do PS4 form factor. 2.5ghz on N3P will be crazy efficient.
You're right and I was wrong it seems. New pipeline allows AMD to do more with less + SE issue was overblown. -33% SE (also RB + Rasterizer) vs PS6 won't matter that much. Kepler also confirmed expanded dual issue for RDNA5, that'll help boost IPC a lot.I expect PS6 to be comparable to AT3 / Medusa Halo
Now that AT4 dGPU should be ~9060XT according to Kepler the 2X bigger AT3 dGPU should indeed be comparable to the PS6.
the power budgets are vastly different between 48cu AT4 vs 54 CU PS6I'd say the 48CU AT3 would need to be ~12% higher clocked than the PS6's 54CU for them to be comparable.
Looking at how Sony bet a lot on clockspeeds for the PS5, I don't know if that will be the case.
Actually, if the AT3 dGPU uses 16 channels * 24bit LPDDR6 14.4Gbps then its RAM bandwidth will be 691GB/s. If the PS6 goes with 160bit GDDR7 as currently rumored, then it's 640GB/s.One place the PS6 will have the edge is in using gddr7 memory. sony has always gone for bonkers memory. so in memory bound scenarios the PS6 should come ahead
Thought PS6 was 52CUs with 2 disabled.I'd say the 48CU AT3 would need to be ~12% higher clocked than the PS6's 54CU for them to be comparable.
Yeah GDDR7 gonna guzzle electrons in comparison to 384bit LPDDR6 But -370mhz will bring power down that's for sure.the power budgets are vastly different between 48cu AT4 vs 54 CU PS6
One place the PS6 will have the edge is in using gddr7 memory. sony has always gone for bonkers memory. so in memory bound scenarios the PS6 should come ahead otherwise it will be in ballpark of AT4
LPDDR6 has ECC overhead. 256/288 x 640GB/s = 569GB/s. I don't expect it to tap out LPDDR6 standard though but perhaps things will change ~2-2.5 years from now. Maybe ~13gbps. ~500GB/s.Actually, if the AT3 dGPU uses 16 channels * 24bit LPDDR6 14.4Gbps then its RAM bandwidth will be 691GB/s. If the PS6 goes with 160bit GDDR7 as currently rumored, then it's 640GB/s.
Things will change drastically if the AT3 dGPU only uses LPDDR5X, though.
Could be. Nothing is confirmed it's just speculation based on AMD patents and research papers.ML upscaling in playstation 6 will be a huge leap forward
