- May 16, 2008
- 3,180
- 0
- 0
i had no idea what a WHEA was until last week because of reading about it on AT. good to pay it forward.
go to your Event Viewer under Adminastrative Options, open up Warnings, then go to WHEA logger and double click it. on the right hand side pane a bunch of options appear under Actions - under actions go to "Attach Task to this Custom View"
Name your task, hit next. Then 'When an Event is Logged' is next, click next - then under Action select Display a Message. then finish.
voila. you get a little pop up box when a WHEA happens.
Do you have to have an actual existing Warning event for WHEA (and see it in the list of warnings)?
When looking at the warnings I didn't see any WHEA warnings nor an option anywhere. I also tried searching for WHEA in the warning event list to no avail.
