Originally posted by: zaku
how much does it cost to refinish and how often does it have to be? would you have to refinish platinum?
Originally posted by: alkemyst
Summary of Platinum?s properties
natural white color (will stay white)
looks better than white gold when it is old and scratched (white gold is white due to a rhodium coating)
heavier than gold
will wear better and last longer than gold
is very expensive, also a 95% pure alloy.
Summary of white gold?s properties
stronger than platinum (good for a ring to be)
more rigid than platinum (again important)
half the price of platinum
Most white gold rings will have a platinum crown...they are less apt to bend, but more apt to break off.
Platinum is harder to work as well....there is a debate about what makes the better crown.
White for a ring is a choice mostly to not color the diamond with yellow.
heavier than gold
you could have just
[S=http://www.ultimatewedding.com/articles/get.php?action=getarticle&articleid=199[/S]https://LINKED![/S]
heavier than gold
you could have just
heavier than gold
Originally posted by: Eli
Go Sterling Silver.
Go Sterling Silver.
Originally posted by: Veramocor
Also if your planning on doing any work with chemicals the platinum is the gold standard, no pun intended, when it comes to inert metals. For example mercury will react with your gold ring, but your platinum ring would be fine.
Originally posted by: bozack
Can't add too much to Alkemyst's post other than the fact that not all white gold is rhodium coated, in fact in Europe selling coated white gold or white gold made with a high nickle content is no longer allowed due to the few reactions some had to nickle...now a good deal of white gold overseas is made with Palladium I believe....also some white gold is just heavily saturated with nickle and not plated at all, only problem with this is it isn't highly white and you are more likely to show an allergic reaction to nickle, that is if you are allergic to it in the first place.
Also Alkemyst is incorrect in saying that white gold is *stronger* than platinum, white gold is more resistant to minor surface scratching than platinum due to its higher rigidity(sp?) and in some cases its rhodium coating, but platinum is definately a stronger more lasting metal (which alke pointed out under plats properties), chances are at one point in a lifetime a gold ring with heavy wear will have to have a shank repair done whereas plat should last well beyond a normal persons life. As for settings, generally platinum is preferred, in fact I have yet to meet a jeweler that does not do all of their setting work in plat.
As for which to get it is really a matter of taste and budget...if you don't like a heavy ring then don't get plat, if you like a heavy ring and want something that will last forever and don't mind spending nearly three times as much then get platinum....personally my college ring is 14K white gold and my wedding band is platinum, I like them both but the white gold ring is alot more comfortable due to the weight savings.
