Originally posted by: RagingBITCH
Originally posted by: funboy42
Front Projection FTW
Screw your puny 80' or less pictars, give me 100 inches or more!
WTH if your going with a rear projection tv you have to change a bulb it it as well if it isnt a CRT rear projection tv and if your going to do that you may as well go for BIG since thats why your buying it anyway.
I went FPJ 100" and will never go back, cant watch a movie on anything else anymore.
OP update the poll with front projection you bias sob 😛
Projection isn't an option for most people.
Neither is the others because of the price-size
I'm thinking about getting CRT rear projection.
DONT DO IT!!!!
WHY NOT????
CRT rear projection uses Direct View Technology. Basically, if you are not sitting directly in front of it at the right height, the picture gets dark. They are bulky, and just not as nice as some of the other technologies out there. If you really want to get a Big Screen TV, either save up the money if you need to or just spend a little more on a different technology.
You can thank me later for the heads up.
BUT CRT rear projection give you the best picture with the best contrast ratio of anything else on the market. Plus it will outlast almost anything with a tube life of over 80,000 hours.
But because you have to sit in front of it is the only reason one shouldn't get one?? Thats bull sh!t reasoning. You saying get a lcd or pay out the ass for something else that also smaller but looks like sh!t com paired to the picture quality a CRT rear projection can produce because you cannot sit to the far side to the tv
😛 For your information on the much newer sets that has pretty much been addressed, and they are actually stop making CRT tubes because there really no money in them. So if you can get your hands on one and rear projection is you thing or way to go CRT is the ONLY way I would do it. They are faxing them out because DLP is much cheaper to produce now, and the crt tubes last to damn long and when they break people buy newer set with the newest technology. Except today everything has a stupid fvcking bulb in them forcing you to purchase a new bulb every 100-3000 hours to keep using the set.
WHY I mentioned above if your going to go with a rear projector now a days and its not a CRT read projection you may as well go frontal so you can atleast got huge ass screen if your forced into buying damn bulbs all the time. Not to mention front projectors are cheaper, and its slowing getting to the point you dont have to have a completely pitch black room to own one, and HD is around $999 to start.
If you go rear projection, and I dont care if it is LCD or DLP, it WILL have a bulb that needs to be replaced. It will go out sooner or later, and will cost you $250-$800+ depending on the set. So if you paying for a bulb why settle for 50~ inches when you can do 100 to 350 inches and cost much less. Not to mention comes with a better warranty. A rear projection may have, if your lucky, a 1 year warranty. My optoma H31 has a 3 year and cost me $599. I went from a Rear 65" to a 100" front projection and I will never look back. Im looking forward to getting a ceiling mount and a 150" screen soon.
Front Projection FTMFW
5TH
5TH again
