poofyhairguy
- Nov 20, 2005
- 14,612
- 318
- 126
Be careful settling on RAID based options HardTech. Everyone around here pushed RAID options when I was looking for a media server, and I found them all to be a poor fit.
Why RAID 5 or 6? Both are designed for business use, and require expensive and overkill RAID cards to get maximum performance.
Really for a media server there are two good options: WHS and Unraid
You go for WHS if you want to do many other things with your media server. With the WHS pluggin community you can quickly have the box not only serving media, but also downloading torrents and steaming them to your PS3.
You go for Unraid if you want maximum storage. Unraid gives you every advantage of JBOD-add any disk you want to the array of any size/speed you want and get full use of it- with the bonus of RAID 5 like single disk parity. Since it doesn't stripe the data its not nearly as dangerous as RAID 5- if three disks die the maximum you can lose is the data on those three disks, unlike RAID 5/6 where you are toast. In my experiance my Unraid box easily maxes my gigabit network- anyone that thinks they need more performance for a home server is kidding themselves.
So since there are the same price, which one to pick?
Pick WHS if you prefer to have your server multitasking, and if you entire environment is Windows anyway (which you said its not). The WHS community's pluggins can't be beat. But don't pick WHS if you are after maximum server size- instead of parity you basically get duplication which uses (wastes IMHO) a lot more disk space than Unraid.
You pick Unraid if you want a NAS and nothing but a NAS. Its single disk parity system (up to 20 drives!) makes way better use of space than WHS. But the flipside to Unraid is that is it based on the extremely primitive Slackware Linux. I am a huge Linux guy myself (used Ubuntu since 2004), but even I don't have patience to mess with Slackware. The community has done a good job expanding Unraid with extra services, but honestly its a PITA compared to WHS to get your Unraid box to multitask.
Personally, my previous JBOD server was multitasking so when I decided to move on WHS seemed like an obvious choice. In the end though I went with Unraid because I preferred all my data to be semi-protected not just the data I chose to be duplicated. My solution is to build one of my HTPC frontends into a monster so it can do the AirVideo/TorrentDownloading/etc. that my server formally did.
If you want free options, there is Flexraid. I don't have much experience with it personally and I don't like that it doesn't have live parity.
By the way, I had the same basic thread a few months ago to learn all this stuff. Here it is for a reference:
http://forums.anandtech.com/showthread.php?t=2071210
Last thing: What about RAID 1?
Sure go for it. If you are rolling in money enough that you can pay for twice as much storage as you expect to use, and you plan to use a Norco 20 bay case so that you have enough drive slots to grow to a decent size, then go for it. It is the safest option.
But personally media isn't THAT important. If you lose a little its not the end of the world. I wanted a little protection (say enough for one disk to die), I wanted to maximize my hardware space, and I wanted to be able to use the disks I wanted to. That solution is called Unraid. You should look into it. And before you ask: I ONLY use OSX and Unraid works great for me.
