Plan to get revenge on a soda theif at work
kevman
3,548
i think you should incorporate urine and/or feces in your plan...
Fausto
26,521
Originally posted by: Dopefiend
Simpsons style- go to a Home Depot (or wherever it is you guys go for DIY stuff) and pop each can on a machine that'll shake the living daylights out of them. Place said (now rumbling and wheezing) cans back in fridge, stand back and admire the explosion.
Wouldn't work. A relatively small amount of time in a cold fridge would settle them down.
maziwanka
10,415
Originally posted by: Marlin1975
Originally posted by: MrDingleDangle
its cans normally
What to do is drill small hole in bottom. Take soda out. Fill can with cooking oil, sour milk, watered down mayo, etc... seal can up and put back in fridge.
Put your name on the bottom so if they try and say "I thought it was mine..." they will be sos.
while this is amusing, i believe this wouldnt work either. the can wouldn't make that pressure release noise when opened. i would be wary of any can that didnt make that noise when opened.....
imported_Phil
9,837
(sigh) Do I have to think of everything? ;)
Nick said shaking machine, take it to work. Shake the entire fridge if necessary :D
Jan 18, 2001
14,465
Attach a perfectly good soda can to 6 or 7 other soda cans that have been emptied and filled with noise producing material.
TitanDiddly
Guest
Dec 8, 2003
12,696
The following text is for entertainment only. Never, ever attempt this.
Get a can of a less-carbonated, drink- Mt. Dew, or maybe some juice if the theif will take juice. Get a hypodemic needle (know a diabetic?), then go to the pet store and get some 'Neutral Red'. It's a red dye that goes through your system the same color it went in. Turn the can upside down, then carefully poke a hole in it with the needle (this is why non-carbonated would be good), and inject some Neutral Red into the can. Remove needle and cover the hole with a tiny dab of hot glue. Spin it around a little bit to mix it up (shaking would be a bad idea), then place it in the fridge. At your own risk.
aolj
1,383
:shocked:
Chunkee
10,391
put R O N S O N O L on the top of the can, it will evaporate but taste like sh*t when he or she drinks it, make get a little sick also
naptha rules
Hammer
13,217
Originally posted by: Bryophyte
Originally posted by: KEV1N
There's this clear solution that nailbiters apply to their nails that's supposed to taste like ass, subsequently discouraging the nailbiting. I would get this solution and paint the rims of the cans :)
That is the best solution. Excellent! You could watch for the expression on the thief's face.
this sounds like the best solution so far
blahblah99
2,689
Go buy some generic cola and put it in the fridge and never drink it. WHen you notice one can is missing, walk around and find that generic can of soda!
Phoenix86
14,644
10
The web cam (in the fridge) is the best solution. The rest, while creative have couple of problems. If you tamper with the can you won't get to 'see' the results, since you don't know who it was. Doesn't necessarliy stop it either (could be a 'bad' can of soda) depending on what exactlly is done. Also, you could lose your job, or worse, get a visit from the law (some of these things are a hair away from poisioning).
imported_Phil
9,837
Yarr, 'tis a good point, to be sure.
Ninjja
1,552
Originally posted by: xSkyDrAx
Shake them up real bad and then let them have it. :)
I think this one is simple, but awesomely effective. Just put some kind of smal indicator on it, so that you and your coworkers know not to take it.
Armitage
Banned
Feb 23, 2001
8,086
The problem with marking cans is that the thief will just claim that he "picked up the wrong one".
MagicalPixieSticks
9
Heres two more ideas.
1. Get someone with a cold, the flu, AIDS, whatever to lick the can and then put it in the fridge, then whoever calls in sick the next day is your thief.
2. Buy yourself a gun and shoot everyone in the building, your bound to get the right person eventually.
BooGiMaN
7,955
seriously your best solution is to do nothing but make the theif think you did..
let him steal a few more sodas then post up a message on the fridge addressed to the theif saying that you have leaving a 'surprise' on the rim of the cans for him, then ask him if he has enjoyed it.
