I bought Pioneer DVR-108 last week, haven't successfully burned one single DVD+R so far. It works fine with DVD-R, but it doesn't work with my CD-RW disks either.
When using DVD+R disks, Nero gives the following error msg:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 6/17/2003 3:25:04 PM
Nero version: 6.0.0.9 (Nero Express)
Recorder: <PIONEER DVD-RW DVR-108> Version: 1.14 - HA 3 TA 0 - 6.0.0.9
Adapter driver: <nvatabus> HA 3
Drive buffer : 2000kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <PIONEER DVD-RW DVR-108 >Version: 1.14 - HA 3 TA 0 - 6.0.0.9
=== Scsi-Device-Map ===
CdRomPeripheral : PIONEER DVD-RW DVR-108 nvatabus Port 3 ID 0 DMA: Off
CdRomPeripheral : CDWRITER IDE5224 nvatabus Port 3 ID 1 DMA: Off
DiskPeripheral : ST3120026A nvatabus Port 3 ID 2 DMA: Off
DiskPeripheral : Maxtor 4D040H2 nvatabus Port 3 ID 3 DMA: Off
12:43:50 PM #30 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
12:43:50 PM #31 CDR -1066 File ThreadedTransferInterface.cpp, Line 1620
Invalid field in command
12:43:50 PM #32 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1620
Could not perform end of Disc-at-once
12:43:50 PM #33 Text 0 File dlgbrnst.cpp, Line 1703
12:43:50 PM #34 Text 0 File dlgbrnst.cpp, Line 1703
12:43:50 PM #35 Phase 38 File dlgbrnst.cpp, Line 1843
Burn process failed at 4x (5,520 KB/s)
Anybody has seen this problem before? Maybe I should go for NEC rather than Pioneer next time. My NEC 2500A works just fine.
Windows XP 5.1
IA32
WinAspi: -
