inf64
Over at XS some real results from 8350 user(for a change). User has access to previous flagship FX8150 and 2600K as well. User is an architect that can make use of good rendering performance (as can be seen later on in real life 3dstudio max benchmarks he posts).
link #1
link #2
link #3
Results summary:
C11.5(old engine) shows ~5% improvement vs Bulldozer version 1 (8150) at the same clock. But then user tested 3dstudio max Vray ( areal world benchmark):
Last link is X264 benchmark at 4.5Ghz (for FX8350). FX8150 was @ 5Ghz, 2600K was @ 4.9Ghz and 4.5Ghz, FX8120 @ 4.5Ghz and i7 hexa core was @ 3.57GHz.
FX8350 @ 4.5Ghz scores : the same as FX8150 @ 5Ghz (so ~10% better IPC in this case) , the same as 2600K @ 4.9Ghz, slightly better than i7 980x @ 3.57Ghz and 5% better than 2600K @ 4.5Ghz.
Edit: for the record (and to avoid 8C vs 4C posts by intel fans). FX8350 has 4 (four) dual threaded FP units,just like QC i7 do. So in all the FP/SEE intensive workloads it's actually 4 FP units (8 thread capable) Vs 4FP units (8thread capable). FX8350 has indeed 8 integer cores that share those 4 FP units, so in some pure integer workloads FX does really good with its 8 integer "cores".
link #1
link #2
link #3
Results summary:
Images of all 3 benchmark runs are in one of the links above so no need to link them here again. Point is FX8350>2600K at the same clock in V-ray by 7%. At stock vs stock the difference would be higher (in favor of FX8350 of course).But in realworld application , with the two famous 3D aplication + renderer : 3dsmax 2011 + Vray 1.5SP5 , the thing you already know seem to be stronger.![]()
Rendering time (second): Lower is better:
- FX 8120@4.5ghz : ~ 679s
- I7 2600K@4.5ghz : ~ 621s
- The thing you already know :~ 580s
