Question PiHole Lists?
Homerboy
30,890
5,001
I just set up a PiHole on my network yesterday and it generally seems to be running ok (except stupid AT&T doesn't let you change your DNS so that's a pain in the butt. At least my Ubiquity AP allows for manual DNS)
However, it still seems on some pages that ads will load (like the big banner ad at the top of CNN.com. I'm trying to find the latest and greatest lists out there, but I can't seem to find a good (new) comprehensive list.
Any help or ideas?
ch33zw1z
39,813
20,423
I could go that route, or as suggested earlier, let pihole handle the DHCP aspect of everything. That's all just more work and it seems like it's working fine now by manually setting the IPv4 properties on the 2 hardwired PCs in my house and then on my Wireless AP seeing the DNS to the pihole.
If you're happy with that, let it ride. No need to get all crazy about it. I will say my ER-X let's me change DNS for each of my VLAN's. The flexibility is nice.
Reactions: Homerboy
sdifox
100,843
18,070
If it's a ISP gateway, probably modem/router device.
Maybe he can set the ATT gateway to bridge mode and get a standalone router to run everything
Yeah you can always disable the router portion and just have it on bridge mode.
Homerboy
30,890
5,001
Yeah it's more than enough. Nothing complicated at my house so if it works, it works.
ViviTheMage
36,189
87
madgenius.com
If you want to pump up your blacklists, I went a little crazy, but the only issue I have is clicking referral links from slickdeals or other sites that rely on referrals. This is my list set:
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
https://mirror1.malwaredomains.com/files/justdomains
http://sysctl.org/cameleon/hosts
https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
https://hosts-file.net/ad_servers.txt
http://winhelp2002.mvps.org/hosts.txt
https://hosts-file.net/grm.txt
https://reddestdream.github.io/Projects/MinimalHosts/etc/MinimalHostsBlocker/minimalhosts
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/KADhosts/hosts
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/add.Spam/hosts
https://v.firebog.net/hosts/static/w3kbl.txt
https://adaway.org/hosts.txt
https://v.firebog.net/hosts/AdguardDNS.txt
https://raw.githubusercontent.com/anudeepND/blacklist/master/adservers.txt
https://v.firebog.net/hosts/Easylist.txt
https://pgl.yoyo.org/adservers/serverlist.php?hostformat=hosts&showintro=0&mimetype=plaintext
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/UncheckyAds/hosts
https://www.squidblacklist.org/downloads/dg-ads.acl
https://raw.githubusercontent.com/bigdargon/hostsVN/master/hosts
https://v.firebog.net/hosts/Easyprivacy.txt
https://v.firebog.net/hosts/Prigent-Ads.txt
https://gitlab.com/quidsup/notrack-blocklists/raw/master/notrack-blocklist.txt
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/add.2o7Net/hosts
https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/master/data/hosts/spy.txt
https://raw.githubusercontent.com/K...d_survey_blocklist/master/w3tech_hostfile.txt
https://www.github.developerdan.com/hosts/lists/ads-and-tracking-extended.txt
https://hostfiles.frogeye.fr/firstparty-trackers-hosts.txt
https://s3.amazonaws.com/lists.disconnect.me/simple_malvertising.txt
https://hosts-file.net/exp.txt
https://hosts-file.net/emd.txt
https://hosts-file.net/psh.txt
https://mirror.cedia.org.ec/malwaredomains/immortal_domains.txt
https://www.malwaredomainlist.com/hostslist/hosts.txt
https://bitbucket.org/ethanr/dns-bl...bad_lists/Mandiant_APT1_Report_Appendix_D.txt
https://v.firebog.net/hosts/Prigent-Malware.txt
https://v.firebog.net/hosts/Prigent-Phishing.txt
https://phishing.army/download/phishing_army_blocklist_extended.txt
https://gitlab.com/quidsup/notrack-blocklists/raw/master/notrack-malware.txt
https://v.firebog.net/hosts/Shalla-mal.txt
https://raw.githubusercontent.com/StevenBlack/hosts/master/data/add.Risk/hosts
https://www.squidblacklist.org/downloads/dg-malicious.acl
https://gitlab.com/curben/urlhaus-filter/raw/master/urlhaus-filter-hosts.txt
https://raw.githubusercontent.com/D...rsions Anti-Malware List/AntiMalwareHosts.txt
https://zerodot1.gitlab.io/CoinBlockerLists/hosts_browser
https://raw.githubusercontent.com/quidsup/notrack/master/malicious-sites.txt
https://raw.githubusercontent.com/quidsup/notrack/master/trackers.txt
https://hostfiles.frogeye.fr/multiparty-trackers-hosts.txt
https://raw.githubusercontent.com/Perflyst/PiHoleBlocklist/master/android-tracking.txt
https://raw.githubusercontent.com/Perflyst/PiHoleBlocklist/master/SmartTV.txt
https://raw.githubusercontent.com/Perflyst/PiHoleBlocklist/master/AmazonFireTV.txt
https://v.firebog.net/hosts/Airelle-trc.txt
https://raw.githubusercontent.com/HorusTeknoloji/TR-PhishingList/master/url-lists.txt
https://v.firebog.net/hosts/Airelle-hrsk.txt
ch33zw1z
39,813
20,423
Wow, that's a lot of lists. How much additional benefit do you see?
For instance, the default lists take care of ads in web browsers very well, and even removes the ads on my roku and in the roku channel.
But youtube and hulu still get thru. Do any of those lists block either or both or those?
Hail The Brain Slug
3,889
3,329
Do you have IPv6 enabled on your home network? I've had a constant issue with my router advertising itself to all devices on the network as a DNS.
No matter what I do, every device has the router as one of the IPv6 DNS options. Even disabling the router's DHCP server and using the built in pi-hole DHCP, the router still advertises itself and every device picks it up.
Your AT&T router might be doing the same thing.
Fortunately for me, I can force the router to turn around and use the pi-hole as a DNS. But it still introduces minor issues as the router runs its own DNSMasq server and caches stuff. It's really annoying when I have to disable the pi-hole for something yet the request still goes to the router via IPv6 and the router returns it's cached 0.0.0.0.
Also, I use https://dbl.oisd.nl as a blocklist. It's a curated "master list" that has somewhere in the neighborhood of a million blocked domains.
bigi
2,490
156
So, I wanna move my PiHole to my router. Currently, I have it in bridge mode running in docker off my NAS.
What IP exactly do I need to reserve and set it as? Its own IP (within NAS) or NAS' IP?
... and then point to it in my router
sdifox
100,843
18,070
you are gonna have to check if you can assign an ip to a docker. if you can, do it and on router point to that ip as dns.
bigi
2,490
156
I can assign IP to NAS and to the instance of Docker/PIhole which are different. So, just use what I've reserved for Docker/PiHole?
pauldun170
9,530
5,758
@Homerboy please give a review after using it for some time.
Let me know if there are problems with shopping because my wife would hate that.
I've had mine running for a few months now. Ran into the wife "Shopping" situation where pictures were missing on whatever website and crap like this.
For the rare occasions that we bumped into it, its super simple to add an exception to allow specific lists in.
Log into pihole, pull up the blocked resource (will show up in the log) and you can allow it.
Reactions: Fanatical Meat
mxnerd
6,799
1,103
According this post, you can run PiHole on any model of Raspberry Pi.
sdifox
100,843
18,070
It's a very simple thing, not much resource needed to run it.
mxnerd
6,799
1,103
Yeah. Don't have to run it in an x86 VM.
You can also download a distro of DietPi (a very lightweight Linux using text based UI) for many supported SBCs and run PiHole in addition to other software.
Reactions: ch33zw1z
ch33zw1z
39,813
20,423
I ran into a problem over the weekend with the default lists and Roku / Hulu. Hulu would load the sound but not video. After confirming Both my Roku's were having the problem, I started looking at pihole. Trial and error == dpm.demdex.net needed to be whitelisted for hulu to work.
Reactions: mxnerd
mxnerd
6,799
1,103
Reactions: ch33zw1z
ViviTheMage
36,189
87
madgenius.com
The only issue I ran into was short links being blocked. I was looking for spam, ad, and malware blocking specifically. You'll want to look for a different set of lists for blocking services.
ch33zw1z
39,813
20,423
My bad, I meant blocking the ads on Hulu and YouTube. But I doubt I find anything that still allows them to work while blocking ads.
I guess I could use pihole to block those services if I want. I blocked some website my younger son wouldnt stop visiting instead of doing his remote learning this spring, he was pretty upset :eek: :p
ViviTheMage
36,189
87
madgenius.com
Yeah, you would have a hard time blocking ads in those services without having a usable service, pretty sure they use the same cdn's.
I've actually never used pihole to block specific services, do they have good lists for that?
Feb 4, 2009
35,862
17,406
I still haven’t put a pi hole in place yet.
Is it possible to put a roku outside of the pi hole?
ch33zw1z
39,813
20,423
Absolutely. You can turn on the pihole, and only point to it things that you want to use it, as long as the device allows manual DNS server config.
ch33zw1z
39,813
20,423
I'm not sure. I use default lists just for ads, people get pretty into it tho, but I guess you could just block URL's like *.Hulu.* or something like that
ViviTheMage
36,189
87
madgenius.com
I just switched to pfBlockerNG-devel, since I already have pfsense setup. It's blocking basically everything I want from the get go. I might roll with this for a few weeks. Would be nice to shut off a VM.
I should add you can import other lists as you see fit, like msot of firebog's:
sdifox
100,843
18,070
And you can use the pihole lists as well.
