Originally posted by: MaDfLaMe37
So I've come to the conclusion that I'll want to overclock the CPU/GPU and I'm thinking that my current PSU (a 430W) might not cut it. So I was looking through the most recent buyer's guide and they went with a Enermax EG565P-VE FMA2.0 SLI 535W on the high-end system which is actually a couple dollars cheaper than the SeaSonic. Would there be any problems/reasons not to swap these two?
Also, is there any truth to what GuitarDaddy said about the Chaintech allowing good overclocking with the new BIOS? Or should I look at a different mobo? If so, which one would you suggest?
430 watts is more then you would ever need for that system, I would stay with the Seasonic.
You're overclocking will be determined by the motherboard, CPU cooling, and just how good the particular chip you have is.
