MaxFusion16
f=ma
done
done
I think you're making this too complicated. You're right about friction being present in other places than just between the wheels and the pavement, but in these type of problems it's just assumed that the other mechanical parts are ideal and so have no friction. In that case it's easy to find whereas otherwise it'd be way too hard for intro physics classes.Originally posted by: DrPizza
I just searched through a couple of college physics books. I couldn't find anything about rolling friction. But, now that I've thought about it, in problem 1, there is no coefficient of friction to calculate. The problem is too complex - it depends on where the friction comes from. Imagine that the tires are held onto the wagon with bolts and washers. If you tightened the bolts too much, it's going to create friction when you attempt to spin the wheels. The amount of friction between the washer/wheel/wagon is independent of the mass of the wagon (and therefore the normal force).
Pour some mass into your wagon - enough to double the mass, and I highly doubt you'll double the force of friction. The force will be somewhere between the original force of friction and twice the original force. I'm on a physics listserv - I'll ask that question of all the other physics teachers/profs on the same listserv tomorrow.
I'm not trying to take it too far. Finding the coefficient of friction in the first problem is inappropriate and a poor example of physics. If a high school teacher is going to make up physics problems, then perhaps they should make up problems that actually involve the physics principles that they are examining, rather than reinforce students' misconceptions about friction because the problem presents an "obvious" method to find the solution. Unfortunately, the intended method to find the solution is irrelevant to the actual solution.
In the case of a rolling wheel, there is NO, I repeat, NO kinetic friction, unless the tire is also skidding against the ground. When you are driving a car down the road, the type of friction existing between your tires and the ground is STATIC friction. But, even that's incorrect as traction with tires is more complicated than the simple physics principles being taught with F=uF. Note: the most common misconception about friction is that it is dependent upon the surface area. This is incorrect. However, in the case of car tires, the amount of traction *is* dependent on the surface area. Traction is too difficult for high school, or college physics. If it wasn't, then it would be a piece of cake to develop the most ideal tire tread and all the engineers at goodyear, michelin, etc. could retire and go home.
Originally posted by: BigPoppa
Just assume the wagon doesn't have wheels.
Dr. Pizza is right in that there is no (rather, limited) kinetic friction between a rolling wheel and the surface it travels on. The teacher should have just made the wagon a simple box.
I'd appreciate it if physics profs. would take the time to make better examples and problem sets. Lord knows I had one hell of a time learning college physics. It doesn't help when your last test has a class average of 53.
So, do you not teach electricity or magnetism, because maxwell's equations are to difficult for someone who hasn't had 3 dimensional calculus?
Do you not teach friction at all, because it's too difficult? people are better off thinking that everything glides smoothly until they become real engineers and work at goodyear?
Do you never teach statics, because it is a limited case of dynamics?
Do you never teach optics, because we still aren't sure whether light is a wave or a particle?
Is it better to give up on a problem, then to solve a simplified model?
