Chode Messiah
- Apr 25, 2005
- 1,634
- 0
- 0
Originally posted by: Chode Messiah
vtol beats conveyor.
Originally posted by: 91TTZ
Infinite power conveyor > finite power vehicle with rolling resistance
The conveyor will just keep accelerating until the rolling resistance consumes all of the vehicle's power. As long as there is at least some friction between the belt and the vehicle, the vehicle has no chance against the all-powerful conveyor.
Originally posted by: JoeFahey1
42
Originally posted by: myusername
Originally posted by: Mo0o
No. the "lift" comes from the air passing through the wings and creating a pressure difference . If the plane is not cutting through the air it will NOT lift off. Another question can be, if you're running on a treadmill holding one of thoes 50c glittering foil fans like 6 year old girls like, will that fan spin?
This is based on the assumption the plane is stationary to begin with and any acceleration attempt forward is countered completely by the coveyer belt carrying it back
Really this is a great analogy! I like the glitter fan.
Except for the fact that the Assumption that is made IS NOT VALID IN PRACTICE.
In real life, if you placed an airplane on a conveyor belt, the airplane would accelerate right off the belt.
Originally posted by: dawks
Why do you keep saying this? It has already been addressed. The wheels would just blow out. Then of course the plane couldnt take off.
But as long as the belt matches, or even stays just SLIGHTLY below the blowout threashold, the plane will take off without issue.
Originally posted by: KillerCharlie
Interestingly, the resistance from the wheels (to a high order of accuracy) depends just on the normal force (weight) of the aircraft, not the speed of the wheels. Given that the aircraft is not constrained in the fixed reference frame, then the conveyor speed actually has 0 effect on the airplane.
This means the ODE governing the aircraft velocity is:
m(dv/dt)=T-D-mu*(W-L)
T=thrust
D=drag
mu=coefficient of rolling friction
W=weight
L=lift
Of course thrust, drag, and lift are functions of velocity. Drag is also a function of lift, but because of ground effect the induced drag changes quite a bit, meaning you'd need a simple numerical ODE solver for this.
The wheel resistance does not depend on the speed, so the conveyor speed is irrelevant (once again, only if the airplane is not constrained in the fixed reference frame). If the aircraft is fixed in the reference frame as per some interpretations, then the thrust needed to cancel out the wheel resistance and keep the plane stationary is constant.
Allow me to quote myself:
T=thrust
D=drag
W=weight
L=lift
This is exactly how the aerodynamic performance people would analyze an aircraft taking off. Note that the speed of the wheels means nothing. The resistance from the wheels is independent of the the wheel speed to a very high degree of approximation.
Originally posted by: DrPizza
For those in the camp that a conveyor with infinite power could keep it from moving, you're forgetting something: you're going to go from static friction (the wheels rolling on the conveyor) to kinetic friction (the wheels slipping against the conveyor). Thus, you're going to see a lot of smoke coming from the wheels as the plane quite possibly moves down the runway. In your scenario, however, the actual amount of thrust the plane/jet can provide is called into question. If the plane/jet has enough thrust that it can move forward with its wheels locked, then the conveyor cannot stop it. If this helps, think of a high powered car spinning its tires while minimally moving forward. That's kinetic friction. It's not enough to significantly move the car forward; what makes you think the same type of force would be enough to retard the plane from accelerating forward?
That's the problem with these hypothetical problems- we're left having to assume that some major condition doesn't apply and we have to solve the problem around that.
If we wanted to be realistic, we'd ask, "why the hell is a giant conveyor on a runway trying to undermine that aircraft taking off?" But it seems that in this problem, we just have to assume it's there. A realistically thinking person would also ask, "How could the conveyor have limitless power?" or "Wouldn't the tires just slip on the belt after a certain point?". In reality these are all valid questions, but in silly hypothetical problems like this we're left having to assume things.
On this problem, it seems to me that they want us to assume that the belt has limitless power and that the vehicle can't get around the belt's influence in any way. So I take it that it has limitless friction, too.
Ridiculous, I know, and you're right that many real-world variables would prevent the problem from working as it seems to be stated.
Originally posted by: mugs
The question doesn't say that the belt will go as fast as it has to go to keep the plane stationary (if that was possible). The question says that the belt matches the plane's speed. It doesn't need limitless power, only enough to keep up with the plane until the plane takes off (which it will).![]()
T=thrust
D=drag
W=weight
L=lift
You're probably right, and in that case, I'll revert to the answer I gave on page 10.
"If this conveyor thing was in place and moved backwards at the same rate which the plane moved forwards, this would NOT stop the plane from moving forwards, it would just double the tire speed. So the plane would still take off at 100 mph indicated airspeed, but 200 mph tire speed"
Page 10?? This thead is only on the 3rd page.
Page references are irrelevant as the number of posts per page is something you can change in the settings. It's pretty pointless to keep the posts per page set low. Even on dial-up, 100 posts per page doesn't slow me down enough to care.
Originally posted by: g8wayrebel
Being that it was a hypothetical question , albeit an impossible one in the first place , you could also assume the infinite speed of the conveyor.
If the conveyor moves as fast as the thrust of the engine is propelling the plane , it never moves. It would sit in place at full speed just rolling on the coneyor. It's forward propulsion would be matched by it's rearward progress on the conveyor, thereby never developing lift in relation to the earth or the surrounding environment , hence: the inability to defeat gravity.
The conveyor is simply a different form of defeat. It negates the propulsion by motion rather than fixed support(ie. a test stand).
How do I look stupid?
Perhaps you could explain how it would take off if it never develops any forward speed.
I would certainly like to hear from someone who is so clearly more intelligent than I.
If I'm pwnd , show me.
EDIT:
This opinion is based on the fact that this is a conveyor. It moves independently. It will move at the same time as the plane attempts to , preventing the plane from making any forward progress. If you think it will still take off if the conveyor matches it's speed and prevents it from moving forward , explain yourself. If not , we aren't seeing the same issue and this is moot anyway.
