- Oct 11, 1999
- 7,804
- 1
- 0
Can you guys/gals please help me with this physics problem??
A 4kg block is given an initial speed of 8m/s at the bottom of a 20degree incline. The frictional force that retards its motion is 15N.
a) If the block is directed up the incline, how far will it move before it stops?
b) Will it slide back down the incline?
How exactly would I go about solving it? I can find the momentum along the x & y components but that won't help me find the force of the block or the work it does.
I found the kinetic energy which also equals work done by the block.
These are the formulas::
Ek = 1/2mv^2
deltaEk = W = Fdcos(theta)
Ek = 1/2mv^2
