Physics Problem: Bernoulli's Equation
Riddleman
346
62. In a very large closed tank, the absolute pressure of the air above the water is 6.01x10^5 Pa. The water leaves the bo0ttom of the tank through a nozzle that is directed straight upward. The opening of the nozzle is 4.00 m below the surface of the water. (a)Find the speed at which the water leaves the nozzle. (b) Ignoring air resistance and viscous effects, determine the height to which the water rises.
I got part A, but don't know if its right since it doesnt make sense in relation to part b. Thanks for checking this out.
Chapter 11 prob 62
globalcitizen
954
I forgot all the physics I did last semester after my final exam so here's a :beer: hoping some of the ATOT guys will help you.
ArmenK
1,600
The nozzle is directed upward, so there is a bend in the nozzle and it points up.
Riddleman
346
Yeah but still, how could the water rise? is my answer for part A right?
kaymin
646
The way they teach introductory phyiscs in college is a joke. Is it possible to blaze through 25 chapters in a term?
The average on my 2nd midterm for physics I was a 22/100. I got a 51:D
Noone ever retains anything, just bs on the test and you'll be good to go.
Armitage
Banned
Feb 23, 2001
8,086
Treat part B as simple projectile motion using the velocity you got for part A.
Indolent
2,128
you can use the general bernoulli equation and cancel out the stuff you don't need, same for the first part. It looks like you are just using a given equation which is a simplified version of this.
p/gamma+v^2/2g+z=p2/gamma+v2^2/2g+z2
gamma is specific gravity of water (9.8 kg/m^3 I believe)
p=pressure
z=height from reference
Just use this equation from the different points in question. I could explain more but I don't have time right now. Hope this helps
Triumph
14
And if you're industrious, you can see that Bernoulli's equation can also be used to find the height (hint, it reduces to the same equation as the projectile motion equation).
