physical difference between cat5 network and cat5 crossovercable
trenchfoot
15,365
7,874
i've never used crossover cable yet, but might and i'd like to know how to tell one from the other as far as their physical appearances are concerned? thx all twks2
TunaBoo
3,280
Hold up both ends together.
If going from left to right all the colors match up, it is normal cat5.
If wires (IIRC) 2 and 6 are switched, it is a crossover cable.
TunaBoo
3,280
<< TunaBoo thanks for the quick reply, you're a slice of heaven. bless you. twks2 >>
Im more a slice of dung that smells like fish.
Anyway, Im not sure I got wires right. But just see if they are identical or not ;)
Bozo Galora
7,271
with both jacks in hand side by side, tabs underneath -
1 on left goes to 3 on right
2 on left goes to 6 on right
3 on left goes to 1 on right
6 on left goes to 2 on right
