Photoshop: is there a way to make every other pixel transparent?
CyberCowboy
I'm using photoshop 7. Was wondering if there was a way to do this.
zoom in, and erase every other pixel.
Make a transparent 2 by 2 pixel file, and make the top left and bottom right pixels white or black or whatever. Select all and define as a pattern.
Go back to your original document, make a new layer, select fill and fill with pattern, choose the new checkerboard pattern you made, and fill.
Select > Load selection, switch to the layer (or layers) you want to change, and hit delete to clear every other pixel.
Delete/hide/get rid of the checkerboard layer from which you made the selection.
At least, that's how I understood the question.
I must be doing something wrong. I can't make a transparent pattern. The pattern just shows up as solid colors. So I get lost after the "Select > Load Selection" part.
And I tried to delete a single color from my pattern layer, but that didn't work either. 🙁
