Photoshop help
Hammerhead
2,297
What is the best way to create an image with a tranparent background. this image has a drop shadow in it.
thanks!
ThePresence
27,727
16
Save as a PNG-24. It has an alpha channel, and will preserve the drop shadow perfectly. It will also depend what you're doing with the image afterwards.
Hammerhead
2,297
thanks. it looked good, but when I put it on a webpage that has a gradient background, the image has a weird blue hue in it.
ThePresence
27,727
16
I can't really be of much more help without seeing what you're doing. Generally with PNG24's , when you are using transparencies there is no color matte, so not sure what is causing it.
