- Jan 2, 2006
- 10,455
- 35
- 91
Originally posted by: Mark R
About your framing:
How did you attach the photo to the back board? Did you use spray mount, DS tape? Or did you leave it unfixed.
I screwed up the attaching to the backboard the first time, so I just hang them from the mount with some paper tape, and just use the backboard for support.
That works fine, but occasionally, the photo bends a bit, and if you're not careful can end up touching the glass.
I went out and got archival acid-free tape. I lightly taped it at the corners and the top to the mat board, making sure that the sides and bottom of the photo hung free. If you tape all sides securely, changes in temperature can warp the photo, so it's best to leave it hanging. The mat board was cut about 1/4 inch smaller than the photo itself rather than flush with the photo, so taping was easy.
Since my tape was double-sided, I lined the backboard with the mat board, sandwiching the photo between them.
I got my frame from http://www.framedestination.com/
I don't have experience with frames without mat boards
