foghorn67
- Jan 3, 2006
- 11,883
- 63
- 91
I know what it is. I use it everyday. But not sure if that was directed at me. Multiple quotes can help in situations like this.May I ask how?
Lightroom is much more than bridge, all edits are non-destructive so no files are actually touched keeping all originals in tact. LR is a database used to import, catalog, and add keywords to photos for easy searching. You can rate photos, sort photos by certain exif criteria (lens used, body used), create virtual albums, apply presets upon import, and much more.
I think the biggest plus for LR over PS is the time it can save you. Try converting a batch of 200 files from RAW to JPEG while applying a custom tone curve, WB, and crop using Photoshop.
Anyway, you can modify your swap file and tweak your catalog settings or break them up. Catalogs are everything about LR performance.
