Philips Sonicare Brushes(2) w/ travel case $69 AR!
ericlp
6,137
225
Originally posted by: sat4fun
Originally posted by: chumbucket666
1) Cleaner feeling teeth.
2) Less brush pressure needed. Great for us with receeding gums.
3) Cheaper brush heads, $4.17 each at Costo. Sonicare = $9.00.
4) Twin speeds.
5) Motor slows down when charging is needed. The sonicare stops dead in mid brush.
The Braun does not have the Quadpacer, but it is easily forgotten after a few uses.
Check with your dentist. I got both sonicare and braun through him and both were cheaper than the same deal at Costco and Sams.
I've used both and perfer the sonicare. I think that maybe you were using too much pressure when you were using the sonicare. You don't use any pressure at all. You just let it lightly glide across your teeth. The Sonic action will do the rest. I've been using my sonicare for over 4 years and I've tried others too because I want to keep my teeth...
Also, don't forget to floss! I hear the braun water picks are good tho, I haven't had a chance to use one... Next purchase I guess. Tho I haven't tried the NEW sonicare yet.
cali99boy
57
Anyone know the differences in the models?
Is it worth it to get the best model?
I see a bunch on ebay, 4400, 4600, plus, 4700, 4800, Professional.
What the heck?
