Phenon II 965 - 3.4 GHz released in the next couple weeks
apoppin
34,890
alienbabeltech.com
Originally posted by: OCguy
Originally posted by: shadyshabby
Will this have any immediate effects on either the price of the 955 black or i7 920 ?
I keep seeing people purchasing the i7 920 from anywhere to 129.99-199.99 and I just can't seem to pull the trigger knowing I would be paying outrageously higher, since I neither live in the vascinity of a Micro center nor do I work at retail store ...
Thx
You think an it 920 is going to bet much cheaper than that? :thumbsup:
There isnt much AMD can do to affect the price of i7.
What would 5.0 GHz do for Phenom II? :p
- hypothetically ??
:confused:
IF somehow AMD got Phenom II to those speeds - at *stock* - in mid-2010; how would it compare - performance wise, then - against stock i7?
You know, like Nvidia does [or Intel did] - eXtreme edition
- water cooled, of course -- no dustBusters - and charge a premium for it
aigomorla
21,126
3,653
so which one of the 3 computers i have listed are you talking about?
LOL :p
Dec 30, 2004
12,553
Thx
- hypothetically ??
:confused:
It still would be plenty fast for all gaming.
apoppin
34,890
alienbabeltech.com
Thx
- hypothetically ??
:confused:
Phenom II X4 is plenty fast for all gaming - now - if overclocked near 4.0 GHz
- all but perhaps TriSLi - then you want overclocked i7
What i was getting at; my point - was that i7 seems to have a 20% advantage or so - when you go clock for clock
- IF AMD was able to ramp up clockspeeds - like P4 Extreme Edition did in the old Athlon 64 days - they might be able to give i7 a run performance wise; certainly in gaming if they got near 5.0 GHz - TriSLi would Fly.
Atechie
60
Thx
- hypothetically ??
:confused:
So not true:
http://www.pcgameshardware.com...with-18-CPUs/Practice/
Expect that picture to become more obvious the longer time passes.
Sylvanas
3,752
Thx
- hypothetically ??
:confused:
So not true:
In gaming the P2 is an excellent choice, it varies on games but as you can see the P2 955 actually beats the I7 920 in Fallout3 and L4Dead (by a very small margin) but it demonstrates what a 3.2ghz Deneb can do - a frequency all Denebs can surpass easily with a little OCing. Then we have the recently released 965, which will push down 955 prices and come stock clocked at 3.4ghz,
Atechie
60
Thx
- hypothetically ??
:confused:
So not true:
I linked to a multicore game...the trend of the future, you failed at relalizing that, I don't care about GPU limited benches when we are talking CPU performance.
Run those test again with the comming GPU and the test will look very differently...
Sylvanas
3,752
Thx
- hypothetically ??
:confused:
So not true:
'The future' is not going to be decided by how CPU limited you are, about as much as it is today, you failed at realizing that. You may be interested in the recent Empire multithreaded patch whereby the extra 4 threads of an i7 920 nets you a whopping +1fps minimum fps and about +3 avg over a P2 940, not 'the way of the future' you'd expect it to be.
apoppin
34,890
alienbabeltech.com
Thx
- hypothetically ??
:confused:
So not true:
FIRST of ALL - that bench is flawed:
Therefore we estimate that the abnormal behavior of the Phenom II CPUs is related to an incompatibility of ArmA 2. Possibly this problem (and several others) are fixed with patches.
We know a Phenom II is at least equal to C2Q - if you clock a C2Q over 20% faster than an i7, you can match it in gaming
http://forums.legitreviews.com/about21970.html
AMD created a small number of limited edition ?TWKR? processors expressly for the extreme overclocking community in appreciation for their record performance feats with Dragon platform technology and AMD Phenom II processors. These processors are designed to reach the utmost performance barriers of the AMD Phenom II processor and operate beyond the specifications of typical production level processors. As speculated, it?s a high current chip that can take the extreme stresses of Liquid Nitrogen overclocking. Our testing of the TWKR showed that we could reach ~6.6GHz on Liquid Nitrogen. It would be a shame if only the top overclockers and media would be able to use these, so we have teamed up with AMD to give away one of these overclocking monsters. With high end air or water cooling you should be able to take a TWKR processor up to 4.0-4.1GHz with ease and for those that want to try out dry ice, liquid nitrogen, or liquid helium you are looking at 5GHz - 7GHz depending on your pot and cooling method. These processors are monsters and have been selected and binned as being the best of the best.
5GHz on an x4 will kick the crap outta a stock i7 now
How the hell am i anticipating AMD's marketing ??
:confused:
it sucks :p
- and i predicted it last night without "knowing" anything
:Q
-- that IS their plan .. super high clocked Phenom IIs - eventually 5.0-7.0 GHz "TWKR" becomes mainstream
:moon: :cookie:
lopri
13,327
708
AMD's yields aren't as consistent as Intel's, and it tends to 'run into' a good stepping when time comes. (Remember how Opteron clocked crazy out of nowhere?) It is always possible that AMD suddenly 'discover' a stepping which is significantly better than previous ones.
That may or may not be the case with 965 BE, but it has been traditionally the case that AMD improves on-die memory controllers with every revision. (does anyone remember CABYE, CAB2E, CCBEE, etc.?) I find it very much likely the 965 will sport a new memory controller. And if AMD can manage to raise the stock NB frequency to 2.2~2.4 GHz, that alone will bring more performance than 200MHz core frequency increase.
It's all about improving the sillicon and how to market it. We shall see when it's released.
Dec 30, 2004
12,553
Why doesn't AMD clock the memory controller higher? If they kept the mem controller voltage the same as the core voltage they could clock it so high..
Sylvanas
3,752
Well, I guess it's a yield issue but I wouldn't be surprised if we see stock 2.4ghz NB P2's soon seeing as pretty much every 955 can reach 2.4ghz NB minimum.
VirtualLarry
56,587
10,227
Apparently, Biostar's "AM2+" boards are actually single-plane as far as voltage goes, so they overvolt the mem controller automatically. See here
That would also increase the TDP, which is why I believe that AMD went to a split-plane voltage in the first place, to decrease TDP.
aigomorla
21,126
3,653
Well let me tell u guys 1 thing...
its a hell of a lot easier to overclock a C2Q and a PHII vs an i7.
Because theres a ton of new rules u need to follow, and you have 3 sets of voltage for the cpu on the i7 that need to be tweeked or your cpu clock will fail.
Also the most annoying thing on a i7... if u failed prime or OCCT on a C2Q, it would just say failed... on a i7 its instant blue screen.
aigomorla
21,126
3,653
Originally posted by: richierich1212
OCCT With PHII instant blue screens as well. It may have to do with the IMC.
oh... interesting...
but u guys still dont have 3 sets of voltage on the cpu alone to fiddle with. :X
Sylvanas
3,752
Yes P2 does, Vcore, NB Vid and the Memory Voltage are all on separate plains on the CPU.
OCCT is fine with my P2 thats what I used to test stability.
aigomorla
21,126
3,653
uhhh...
Vcore
VTT
PLL
QPI/DRAM
http://www.anandtech.com/GalleryImage.aspx?id=6097
^ those are just for the cpu.
Then you got 4 for the board. :p
which are the IOH's and ICH's as well as the PWM frequency now.
... lol its no longer just NB voltage here....
Do i need to say more?
we were talking about when it fails. Do you blue screen? instead of it saying failed overclock?
Sylvanas
3,752
uhhh...
Vcore
VTT
PLL
QPI/DRAM
I didn;t say anything about i7, I don't care as that is not the topic here, I responded to what you said:
Which it clearly does as I pointed out.
No, he did not preface his sentence with "when the overclock fails it exhibits blue screen etc..." therefore what he said implied that running a OCCT on a P2 in general results in a bluescreen which it doesn't, because the P2 runs OCCT fine at stock. It's when you Overclock too high or find instability that it fails and since you asked- for me I just get a freeze and reboot when it fails.
lopri
13,327
708
Why would you want to waste time on voltages? I'd much rather play with straps, multipliers, dividers, timings, etc.
Brute force cooling and endless fiddling with voltages were the main reasons for me to dump C2Q's. Current X58 system doesn't look much better from what Aigo says, it seems. And if you think about why, it's kinda pathetic.
You see, all these voltage fiddlings in i7 system involve QPI, and #1 reason why Intel developed QPI is da license. Even giving Intel the benefit of doubt and assuming performance was Intel's utmost concern, that would be for multi-socket servers, not single-socket desktops. I have no doubt that Nehalem desktop would perfom just as well using HyperTransport which is royalty-free industry standard. And Intel seems to agree! It will reportedly do away with QPI on upcoming LGA1156. (Though we'll have to wait and see)
If you remember Socket 939 platform, you surely remember how much HyperTransport affected overclocking or memory tweaking - i.e. near zero. On the other hand, on LGA1366 QPI (and related voltages) is tightly interwoven with CPU and memory, and is what dictates EVERYTHING when it comes to overclocking. Yet QPI itself has nothing to do with the performance of a system.. It's just an interconnect between CPU and the north bridge (which is a PCIe controller for the most part) Thus its main purpose of existence is to prevent anyone from making platforms or devices for Nehalem without Intel's permission. And You will not likely see any reviewer questioning why QPI is so important on X58 yet doesn't even exist on P55. But be that as it may.
I have absolutely no interest in wasting my time and energy on tweaking voltages, which contributes nothing to performance gain of itself. I'd leave that to engineers and take for myself multipliers, dividers, and timings instead at any time.
Atechie
60
All I did to get to 3.5GHz on my i7 was:
Set OC in BIOS to manual.
Set BCLK to 175
Disable speedstepping/turbo
Set VRAM to 1.66
Done...speaking from ignorance is selmdom wise...
lopri
13,327
708
@Atechie: You probably should have quoted someone else. ;) I never said that it's difficult to overclock i7.
Atechie
60
You post left me with a different impression...
evolucion8
2,867
I am just going to assume you have problems fully expressing yourself in English.
So let me break it down in a way you might be able to understand :
Me pay 279.99. Me no likey pay so much. Me not rich. Deal for $129 and $199 no worky for me. Wish me could. Make me sad.
You look very sophisticated mocking up someobdy's else lack of english knowledge, me confused. :confused:
Back on topic, even though the Phenom doesn't stand a chance against the Core i7 in most tasks except File Encryption, in games the Phenom is exceptional, it can outperform quite easily it's C2Q siblings thanks to it's architecture and IMC improvements and can get past i7 specially when overclocked, you can argue that i7 overclocks too, but i7 doesn't react exactly the same as the Phenom when overclocked, both are different architectures, but I would give the edge to the i7 when SLI/Crossfire is used, and Phenom II when single GPU configurations are used.
