Hi all,
I have three win2k machines on a network at home using a SMC Barricade... I need to have one of the machines (call it M1) RAS into another network, but I'm having some problems. I was hoping for some help from the experts out there!
Anyway, when M1 is on my network it can see all of the other machines and all is well. Settings are as follows:
LAN:
IP: 10.1.55.162
SUB: 255.255.255.0
Gateway 10.1.55.254
When I RAS in with M1 with the ethernet cable still connected I connect OK and am verified, but I cannot see _anything_ on the remote network. Settings are as follows:
LAN: (same as above)
IP: 10.1.55.162
SUB: 255.255.255.0
Gateway 10.1.55.254
PPP adapt:
IP: 10.1.52.246
SUB: 255.255.255.255
GATE: 10.1.52.246
The strange thing is that when I _unplug_ the network cable from M1 and RAS in everything works OK and I can see the remote
LAN:
cable disconnected
PPP adapt: (same as above)
IP: 10.1.52.246
GATE: 10.1.52.246
I guess it must be something other than the TCPIP settings thats causing the problem since they're the same whether I'm plugged into my local net or not... thing is, I'm a total amatuer at this, so I'm not really sure where to look next. Any help would be GREATLY appreciated!
Thanks!
