Penryn release and availability.
Cheex
3,123
Originally posted by: tenax
i'd try 475 or 480. that was actually easier for me to get to with the ds3 then 435 to 450. just felt easier. 2.2 on my volts (that was with 6400 memory at 4-4-4-12), +.2 on my mch and system volts...cpu at 1.38 ish i recall. still have the board..have to keep it as it was my first 500 fsb board..
Let me get this str8....that's:
FSB = 475-480
RAM = I'll set this according to my memory
CPU = I'll set this according to my cpu
MCH = +0.2
FSB = +0.2
FSB voltage is the same you call system voltage?
tenax
598
i'd tweak all 3 up by .2..it can take it. i ran my 24/7 overclocked to 500 for months with no problems.
Cheex
3,123
500x7 = 3.5GHz
This was my original target for my E6300.
When you say all 3...you mean....???
tenax
598
fsb, mch and system voltages...and then whatever you need on the cpu. i wouldn't go higher than 1.4 volts myself. didn't need to go that high though in my case:) but it was a warm project..(in an htpc case which didn't help) 51 to 52C idle on the cores, 62 peak on load.
conversely, i'm running stock voltages on my ds4, stock 266 fsb, 400 mem speed..only voltage exception the .9 on my cpu..what does that get me? 31 to 32C idle on the cores, 38 to 39C peak:)
everything the same hardware wise except i changed my tt typhoon to an enzotech extreme as it gave more clearance to the top of the case. and of course the mobo..and oh yeah, i added one more pvr card which added a bit of it's own heat.
