Originally posted by: Rogodin2
Either way I'd like to see some source material for your votes.
Thanks
Rogo
Well, of course, it will eventually peak, even with a resource as ridiculously abundant as oil, and that will force people to seek alternatives (by increased scarcity driving up prices) in such fashion that we will never ever run out. Which is a good thing, as oil is valuable for far more things than just burning it for energy.Originally posted by: Born2bwire
Where's the option to say that it'll never peak?
The oil supply is measurable-we have national and global agencies that measure and project field output-it's not infinite.
Rogo
But it's a renewable resource. It'll last forever I say, forever! Or at least for the rest of my lifetime and isn't that what matters?
That's ok. I'm a well-educated American. I can afford it.Originally posted by: Rogodin2
Crude oil will be pumped until there isn't any left-but that's not 'peak oil'. Peak oil is the point at which ulitmate extraction is reached. Think of it as a bell shaped graph with the top of the bell being ultimate extraction-the bottom of the bell the lowest extraction.
You probably won't see oil 'run dry' in your lifetime-but you will see everything in the world that we as humans use become extremely expensive.
Rogo
Rogo
Yes that is true, but as technology advances, more and more oil is measured because it is now attainable, they knew it was there but couldnt get to it. Also as technology advances more sources are found.
Rogo
noone knows the peak until after the fact
Originally posted by: BrownTown
Meh, I just don't know. Maybe all the peakoil and environmentalist people are right but they have serious credibility problems due to the "boy who cried wolf" mentality. The number of horrible disasters predicted by these groups is very large and yet none of them ever comes to pass. Maybe peak oil or global warming will be different, but there is definitely a very valid reason why people are skeptical.
Certainly it is a mathematical fact that some point must occur at which "peak oil" is reached and after which oil production will decline. However the date is very vague (just looking at peakoil.com there are people arguing its 1 year away or decades, I think some may even say its past). Even more vague are the results. Certainly oil is hugely important to our economy, but over time this will change. Economic depression is a likely outcome, but those predicting massive die offs are just silly. for example pressure put on the food supply by lack of cheap fertilizers will be largely offset by a change in crops produced and a stronger push for GM foods. So even in a doomsday scenario I see at most some changes in diets and switch to more GM foods, not anarchy and famine.
ask people 30 years ago if they thought they saw 'the results of it'Originally posted by: Rogodin2
I'm asking you if you think we're seeing some results of it 'being after the fact'.
Brown-I'm not proposing that we're after or before, nor what the outcome will be when and if we've moved beyond. I'm posting this poll because I want to see what a fairly educated cross section of the public believes. I don't assume that any majority of the population even understands 'hard landing, and dieoff'.
Rogo
