[PCPro] Haswell vs. Haswell ES Overclocking
WhoBeDaPlaya
7,415
404
Could I hit my planned 4.2 Ghz OC with a stock cooler? Or even 4 Ghz?
Possibly, depending on the voltage required. The MSI Z87-GD65's "Enhanced Turbo" feature automatically ratcheted up the clocks to 3.9GHz at around 1.25V. Things quickly got toasty running IBT with MX4 and a Hyper 212+ (90C).
Kenmitch
8,505
2,250
Luck of the Draw?
From all the feedback that I am getting through motherboard makers about Haswell overclocking, the basic thread at this time in terms of getting "high overclocks" seems to be, "You need to have a good CPU." ASUS has tested a couple hundred Haswell processors at this time and this is ASUS’ specific feedback from that overclock testing.
70% of CPUs can clock to 4.5GHz
30% of CPUs can clock to 4.6GHz
20% of CPUs can clock to 4.7GHz
10% of CPUs can to 4.8GHz
Overall you will find most CPUs capable of reaching 44x to 45x with varying levels of voltage.
From this article http://www.hardocp.com/article/2013...74770k_ipc_overclocking_review/1#.UbPIcr7n99A
Maybe Haswell needs a new stability testing scenario. Stable at ones intended uses is most likely gonna require less voltage and produce a lot less heat.
blackened23
8,548
Consider that 70% of 4770k samples can hit 4.5ghz, and a 4.5ghz Haswell easily matches an IVB hundreds of mhz higher. I've seen benchmarks of a 4.4ghz Haswell exceeding 10 in cinebench 11.5, which oddly enough is higher than what my 3770k gets at 4.7ghz.
I just don't get some folk's mindset on this. Haswell is not different than IVB, they are both temperature limited - I really feel that some have rose tinted glasses or skewed memories of what overclocking on IVB is *really* like. People are so focused on trash talking Haswell that they forget that IVB really was not THAT much different. It's not all rosy like some are suggesting here, it's not like every 3770k on the planet is going to hit 5ghz with ease. Or even 4.6-4.7ghz. Give me a break. IVB gets hot as well, let's not kid ourselves.
Aside from this, there is the fact that Prime95 increases Haswell's offset voltage by .1V. The temps you see in Prime95/IBT will *not* be replicated anywhere else, you can be certain of that. I think a lot of folks are approaching 4770k stress testing wrong, because prime95 and IBT have not been updated for Haswell yet. Haswell, unlike IVB, increases the offset voltage by a whopping .1V with certain AVX type instructions which only occurs in prime95 and IBT. Even if you get ridiculously high temps in prime95, you will definitely NOT get those same temps anywhere else.
tential
7,348
642
121
I see.... Well, based on the hardocp review it shouldn't be hard to OC I'll just follow the instructions. Not sure how much I'll go up to considering none of the games showed much of any benefit at 1080p.
WhoBeDaPlaya
7,415
404
This is only true if you're running Vcore in adaptive mode. Since I fold, I see no point in offset and/or adaptive mode and just run a fixed Vcore.
My voltage does not exhibit the 100mV increase when AVX instructions are thrown into the mix, both in the CPU-Z and voltmeter readings.
RadiclDreamer
8,622
40
If you really expect an overclock, just buy 20 chips, test them and keep the best, return the rest. That's what I would do if I really wanted an over-clockable product. Next time I'm gonna do just that, I'm sick and tired of getting garbage-bin products, for example my Titan doesn't OC past +50/300MHz, it's fine at 130/300 in some games but total stability is only at +50MHz.
ps. I wouldn't expect a new stepping that improves OC. When was the last time they did that? Almost 4 years ago? (920 G0) The new stepping of SB-E only repaired what was broken, I don't expect anything more from a company that puts a gap between a CPUs die and its IHS. WHY? Higher temps should lead to more silicon degradation thus increase RMAs. Maybe that effect is too miniscule for them to worry.
Intel doesn't guarantee over clocking. Anything you get above stock is a bonus. Buying and returning does nothing but up price and make it harder to return for legit customers.
Vesku
3,743
28
86
But how does it compare in GAMES, specifically Starcraft 2 and Skyrim? The holy grail of benching for a good portion of the "get a dual core i3 over a FX 6300" folk.
Vesku
3,743
28
86
Intel's "Perfomance Tuning Protection" does give the owner 1 no questions asked swap though, right?
"The Plan only applies to issues directly related to performance tuning, and only provides for a one-time replacement for eligible processors. "
Pheesh
138
Haswell OC is so poor...that it's exactly the same as IVB. Sensationalist headlines are funny
blackened23
8,548
Well, that depends greatly on whether the game is CPU limited or not. I play a lot of CPU limited games (eg SC2: Hots, Neverwinter, Planetside 2, even crysis 3, among others) and having better IPC is always desirable. In those games Haswell will be king, whereas you can play something like Metro Last Light which is completely dependent on the GPU - but, games like that are a few among many.
There are some games which don't vary a lot in terms of performance because they're reliant on graphics processing, but looking at the big picture and a wide variety of games, having a balanced system with the best IPC possible is the best approach.
AdamK47
3,638
I never trust overclocking results from average Joes on internet forums. Especially from Overclock.net and HardOCP. Their results are generally only stable enough for them to boot Windows and run a few benchmarks. It would never pass the kind of stability tests I put processors through.
WhoBeDaPlaya
7,415
404
Which is?
AdamK47
3,638
With my current system I used 8 to 12 hours of LinX AVX - 11 threads 28GB memory. Then 8 to 12 hours of Prime95 AVX with 12 threads and 10GB memory. Then around 8 hours of 3DMark11 demo loops using the extreme preset. Afterwards I use a combination of Prime95 or LinX with 10 threads and loop Unigine demos for several hours. While doing the LinX and Prime95 tests I'm also using the system for browsing the web and doing other stuff.
BFG10K
22,709
3,007
If you are basing your purchase off of a review and an expected overclock, that's your biggest mistake.
I agree with this, but the problem in this case is that stock temperatures are also affected, to the tune of 15C. That's alarming as review samples @ stock already had high temperatures.
KingRaptor
52
Haswell's increased IPC is offset by slightly higher OC's of IVB chips, and even higher OC's of SB chips. Unless the new instructions are important to your, Haswell-IVB-SB after OC are pretty much neck to neck performance wise.
xeledon20005
300
seems like lots of work/waiting
Fx1
1,215
Can someone do a test with what clocks are needed to match sandy ivy and Haswell in performance.
Ie. What clock is required to get better performance versus last 2 chips
BallaTheFeared
8,115
Rough estimates!
Haswell at 4.5 equals...
Ivy at 4.8 equals...
Sandy at 5...
Borealis7
2,901
205
is it true that Haswell doesn't have Turbo OC in non-K chips anymore? (raising the turbo by 4 bins)
ShintaiDK
20,378
If we cherry pick alittle and use this bench:
Then a 4Ghz Haswell is equal to a ~4.55Ghz IB and a ~5.2Ghz SB.
But again, depends in what workloads. In Linpack a 4Ghz Haswell equals a 6.8Ghz IB. Other loads, hardly much difference.
blackened23
8,548
I will say this, users at OCN are reporting cinebench 11.5 scores higher than 10 for 4770k @ 4.4ghz, which is higher than my 3770k gets at 4.7ghz. Going from SB to a 3770k myself, the 3770k outscored the SB in all synthetic benches despite having a lower overclock by several hundred mhz - the takeaway point is that the Haswell does not need to be overclocked AS high, even if you are incredibly unlucky with OC'ing it. Oh yeah, just for comparison basis, the 2600k gets around a 6.8 in cinebench 11.5 at stock.
It doesn't matter if the overall OC is 200-300mhz lower due to the IPC increase. It's also completely laughable that the 3770k is now being spoken of as if it's the best overclocker in the world now - it isn't different than the Haswell. It also gets completely hot when over-volted and is temperature limited, people are just wearing rose tinted glasses now.
Borealis7
2,901
205
i still maintain that your 2600K at 50% OC is one of the best OC CPUs we've seen in recent years. i had such high hopes after IVB that Haswell will just have decent thermals under OC and now i'm disappointed.
willomz
334
Haswell absolutely rocks in SC2:
An extra 24% here:
http://www.pcgameshardware.de/Haswe...sts/Intel-Haswell-Core-i5-4670K-Test-1070973/
An extra 16-19% here:
http://www.hardware.fr/articles/897-24/cpu-jeux-3d-starcraft-ii-anno-2070.html
Far above average gains, so you should be able to maintain decent frame rates even in the most intensive (1v1) battles.
Sable
1,130
105
Since when did Intel guarantee overclocking in any of it's processors? :confused:
