PCMark02 analysis help
fustercluck
I just ran PCmark 02 after a while and came out with these results. I don't like the look of that 93 HDD score...even though i don't quite know what it means. It seems rather low compared to most. It didn't give me a CPU score either for some reason. In all of my previous PCmark benches i came out with N/A for both CPU and HDD. Those we're back in December. Anywho, i waited a day and ran PCmark02 again, and got the same results, besides a 1 point higher difference in my HDD score. So why is it so low? What should i do (if anything)?
Did you do a motherboard upgrade and keep the same install of XP? What does it say under IDE ATA/ATAPI Controllers in your device manager?
Maybe you have a bad install of PCMark.
Did you install motherboard drivers?
shouldnt be a DMA problem...I'm still sorta curious, maybe if i figure out what the problem is my computer performance would improve.
