- Jan 7, 2007
- 4,008
- 1,509
- 136
a bit to unpack here
so ECAM is electrochemical additive manufacturing. a bit like electroplating by building up structures from copper atoms in solution in a 3d printer sort of layering. supposedly cheaper than skiving/scarfing.
the process is used to build the gyroid or diamond versions of a triply periodic minimal surface. https://en.wikipedia.org/wiki/Triply_periodic_minimal_surface
dr ian was a little lax in not nailing down how fabric8labs is using the gyroid flow. just running the water parallel to the plate seems like a waste. you would think that they would want to use the 3d volume aspect of TPMS to pump it perpendicularly down and through the gyroid structure.
this is a helicopter oil heat interchange design from advanced engineering solutions. the design is smaller and 4x more efficient than the part it is meant to replace.
the whole point of the schoens gyroid in this use case is 2 separate sides with the maximum surface area between. in a cpu waterblock unless you are separating the water flow to the waterblock into two flows and changing the speed for one side it seems like you arent extracting the maximum value out of the TPMS.
for now i would keep your skeptic hats on, until more details come out.
