PC Power Cooling Silencer Mk II 750W - good or bad? $70
Discussion in 'Power Supplies' started by Shephard, Nov 26, 2012.
  1. Shephard
    Shephard Senior member
    Nov 3, 2012
    766
    this power supply is back on sale.
    do you guys think I should jump on it?
  2. Slugbait
    Slugbait Elite Member
    3,627
    Especially considering the brands you used before, and the subsequent results of using those brands, I certainly would. It may not be a Seasonic, but it's a solid PSU with a great warranty.
  3. xcal237
    xcal237 Member
    Aug 22, 2012
    98
    i have the 950 watt version and so far its rocking my only gripes about it is that its not modular and it has a crap ton of cables...
  4. lehtv
    lehtv Elite Member
    Dec 8, 2010
    11,799
    51
    It seems to be $105 ($85 AR). XFX 750W XXX is $85 ($75 AR) and it's a Seasonic built unit with semi-modular cables. I'd rather have that one
  5. john3850
    john3850 Golden Member
    Oct 19, 2002
    1,307
    Bought a PC Power and Cooling Silencer Mk II 750W with free dvd 99.00 for a new build.
    I am running a 930@4200,1.31v 18g of mem with a 5970 + 5870 using a old orignal PC Power Silencer 750W
    Thats 3 5870 style GPUs on that old 750ps.
    I also avoid using a Modular Power Supply on a high draw system.
    On a non stressed system a Modular Power Supply i cool.
    I have never heard of PC Power, but it is 80 Plus Silver.
    They were one of the first ps with a 4 plug pci-e in that time range.
    #30 john3850, Nov 29, 2012
  6. lehtv
    lehtv Elite Member
    Dec 8, 2010
    11,799
    51
    Why would modularity be an issue in power hungry systems?
  7. john3850
    Oct 19, 2002
    1,307
    Could cause more resistance and or heat at modular plugs.
    Back in the amd cpu days I had two different mb smoke up the 20 pin power connector on the mb.
    After replacing the ps connecter and cleaning ps mb connecter both pc still worked.
    #32 john3850, Nov 29, 2012
  8. lehtv
    lehtv Elite Member
    Dec 8, 2010
    11,799
    51
    That's just one instance, doesn't prove anything either way
  9. Shephard
    Nov 3, 2012
    766
  10. lehtv
    lehtv Elite Member
    Dec 8, 2010
    11,799
    51
    $40ar is a sick price for a 700W unit. As reviewed by hardwaresecrets, that's a decent unit. It's just 80+ bronze but whatever, it's only an issue if you don't mind fan noise at higher loads
  11. Shephard
    Nov 3, 2012
    766
    I don't like rebates because they are annoying to do. plus you can lose warranty.
    $59.99 still seems like good price.
    I don't think the cables are sleeved on this power supply though. might look ugly.
