- Jan 2, 2005
- 367
- 0
- 0
Originally posted by: AiponGkooja
Still looking for more consumer reviews on different TV tuners please. If it helps I am looking at 100-200 for price range and have changed my choice of monitor to this: http://www.newegg.com/Product/Product.asp?item=N82E16824001166
Have you run 16X12 on a 19" CRT yet?
Originally posted by: Fox5
BTW, a 17" LCD is about the same screen size as a 19" CRT.
Anyhow, 1600x1200 on a CRT......well not all CRTs can do the resolution well, besides that you need a pretty fast video card to run it well in modern games.
The Hauppauge PVR series or any of the Theater550 (ATi based) TV Tuners will provide excellent picture quality. Anandtech did a pretty good comparison a couple months ago, look the review up. You can pick up a Saphire Theater550 card for less than $100.
I myself have a Hauppauge PVR-150 and am completely satisfied with it. If I were to buy a TV card right now though, I would most likely get the Saphire Theater550
Is there something wrong with 16x12 on a 19" CRT? That would be annoying seeing as how I ordered it yesterday...
1600x1200 will be fine during gaming but *might* be to high for desktop usage ,but as long as you can read text without straining then it'l be fine, I've been running 1600x1200@85hz desktop res on my 21" CRT (19.8" viewable) for 2 years and it feels 'just right' ,the recommended res is 1880 x 1440 @ 85Hz but its a bit to much even tho it looks sharp & clear.
No, not necessarily. There are two issues I had, one I personally didn't care for it, it seemed to small. Two, my monitor's (Viewsonic A90f+) native res is 1280 X 1024 and it doesn't scale 1600 X 1200 correctly. It may be perfectly fine for you on both accounts.
I thought anything over 60 is fine. My current monitor can only do 1280x1024 max res at 60hz, haha.
The Sapphire Theater 550 is looking pretty good, thank you for the suggestion. Quick question though; will I probably need mce2005 or some other equally expensive software package to get it to work properly?
Edit: Also, what are the advantages/disadvantages of using a pci card instead of an external solution?
Thanks,
Aip
(scratches head) ..did you say native res is 1280x1024 on your A90F+? ..Isnt that a CRT? ..They dont scale like LCDs so it should look fine @ 1600x1200..other than maybe being to small.
EDIT: Just checked Viewsonics site, a90f+ only runs 68hz refresh @ 1600x1200... that alone would be hell on your eyeballs lol.
Yes it is a CRT, and no they don't scale like LCD's but they still scale, and I don't like the larger black border when running 16 X 12. Sure it's adjustable by stretching, but it does not look natural at all.
