Pleasehelp
I had a custom built Windows 7 Pro 64 bit PC built about 4 years or so ago by AVA computers. It's been a great machine.......however......in the past several months I have been having "not responding" problems. For example: I will be using Adobe Lightroom and after working for anywhere from 2 minutes to 2 hours without any problems the PC will freeze. At the top left of the Lightroom program (on the bar that runs across the top of the program) the words "not responding" will appear. Then nothing on the PC works. It just freezes. I can't click on anything. Nothing happens if I try to launch another program, if I hit control alt delete nothing happens. The cursor will still move around but clicking on anything gets nothing in return. After a minute or 2 or 3 if I click back on the screen in Lightroom it turns a see-through white color. From experience that tells me that it will be unfreezing in a few seconds or up to a minute or more. Then everything comes back to normal until the next "not responding" situation hits. Could be 20 minutes. Could be 3 hours. Could be 3 minutes. It's completely random when these things hit. It happens every single day several times a day. (incidentally....remember when I said I clicked on programs and hit control alt delete and nothing happened?.....well.....when the PC comes back to life all those things I clicked on a few minutes back now engage and "come on" all at the same time......it's like if one of the things I clicked on was Google Chrome browser then that will come on....albeit 3 minutes after I clicked on it) . By the way......I mentioned Lightroom as an example above but the problem happens with ANY software.*
Waiting for these random "not responding" freezes to un-freeze can be maddening...especially when working on things that really matter. I have tried everything I know might help. I'm using Norton AV, Malwarebytes, I have run numerous diagnostic checks on the RAM, HD and system. Everything checks out OK. I have cut and pasted my PC build from AVA computers below.*
I will do whatever it takes to fix this problem. If I need new hardware then I'll replace the parts. If anyone here can help me I would be extremely grateful to you. This thing is driving me out of my mind.
**note** All my drivers are absolutely up to date. No problems with out of date drivers.*
+ CUSTOM DESKTOP COMPUTER, Core i7 2-way SLI® DDR3 24GB Performance Series System
ANTEC, Performance One P183 Black Mid-Tower Computer Case, ATX, No PSU
ANTEC, Signature 650 Power Supply, 650W, 24-pin ATX12V EPS12V, One 6-pin + One 8-pin PCIe, SLI Certified
ASUS, P6T Deluxe V2, LGA1366, Intel® X58, 6400 MT/s QPI, DDR3-2000 (O.C.) 24GB /6, PCIe x16 SLI CF /3, SATA 3 Gb/s RAID 5 /6, HDA, GbLAN /2, FW /2, ATX, Retail
INTEL, Core i7-920 Quad-Core 2.66GHz, LGA1366, 4.8 GT/s QPI, 8MB L3 Cache, 45nm, 130W, EM64T EIST VT XD, Retail
NOCTUA, NH-U12P Copper CPU Cooler, Socket 1366
CORSAIR, 12GB (6 x 2GB) XMS3 PC3-12800 DDR3 1600MHz CL9 (9-9-9-24) 1.65V SDRAM DIMM, Non-ECC
GIGABYTE, GV-N96TSL-1GI, GeForce® 9600 GT 650MHz, 1GB GDDR3 1800MHz, PCIe x16 SLI, VGA+DVI, HDMI, Retail
WESTERN DIGITAL, 150GB (WD1500HLFS) WD VelociRaptor, SATA 3 Gb/s, 10000 RPM, 16MB cache
WESTERN DIGITAL, 1TB WD Caviar® Black (WD1001FALS), SATA 3 Gb/s, 7200 RPM, 32MB Cache
RAID, No RAID, Independent HDD Drives
LITE-ON, iHDS118 Black 18x48x DVD-ROM Drive, SATA, OEM
LITE-ON, iHAS324 Black 24x DVD±RW Dual-Layer Burner w/ Smart Erase, SATA, Retail
SILVERSTONE, SST-FP35 Black Internal 30-in-1 Card Reader & I/O Panel Device , 3.5" Bay, USB
MICROSOFT, Windows 7 Professional 64-bit Edition, OEM
