PC Intermittent "Not Responding" episodes.
Pleasehelp
31
Have you tried swapping out the SATA cables?
Welp.....I just swapped out the cables. Computer froze about 10 minutes into after I powered it up.
Ya know whats weird. Lets say the computer just became frozen. With Windows 7 you get that spinning wheel meaning I have to wait a few minutes until things unfreeze. Well....my cursor still works and if I click on a program...for example a browser....and of course nothing happens.....but I click on another program....and then another.....but nothing happens cause the computer is froze. Well......once the computer unfreezes.......all the programs I clicked on start up. All of them. If I clicked three browsers...they all come on.....whatever I clicked on 4 minutes ago now comes on. It's like my clicks are all executed.....but not until the PC unfreezes. What the heck????
Ketchup
14,553
248
It is the system waiting on something. A lot of options here, so the event viewer can be your friend. Windows is pretty good about logging a program, driver, etc. that is extremely slow to respond.
crashtech
10,573
2,145
Problems like this can be maddening to trace. I might boot to a live CD like Parted Magic and noodle around in it for a while. I bet it doesn't freeze in an alternate OS. If this is the case, as an experiment you could toss a blank hard drive in and load up a fresh version of Windows, documenting all changes as you go. If you hit the freeze problem, you have a chance of identifying the errant software. If it never freezes, you may have experienced silent corruption in a critical application file that would not be repaired by sfc /scannow.
Smoove910
1,235
Just a shot in the dark since I didn't see it mentioned...
Is this PC part of a domain or on a home network of some sort? I've seen PC's freeze when it loses connection and is attempting to acquire an ip address from DHCP server. Thought I would ask...
Pleasehelp
31
It's not part of a domain or on a home network.
Pleasehelp
31
What does it mean "the system waiting on something". What could that something be? I see nothing unusual in the event viewer.
Ketchup
14,553
248
A resource. You see things like this on a web browser every once in a while. Like I said, can be hard to track down. what types of devices are attached to your computer?
Pleasehelp
31
Devises attached to computer are....printer (rarely turned on BTW)....mouse, keyboard (both of which I swapped out to see if that was causing the problem), 1 external hard drive, a usb3 card reader, speakers.....that's it.
Smoove910
1,235
disconnect the PC from the interwebs and see if the problem persists. If there's no freezes while disconnected from the web that will give you a clue to look for an application that is accessing the internet.
Underclocked
Is this your motherboard? http://i.ebayimg.com/00/s/NzUwWDEwMDA=/z/mxcAAMXQC-tTDANN/$_57.JPG
If so, look at the lower left in the picture and you will see a battery.
VirtualLarry
56,542
10,167
To test potential driver issues, I would go into Device Manager, and start disabling non-essential device drivers / hardware.
Also consider un-installing Anti-Virus and Anti-Malware software. (Run a full scan before un-installing them though.)
Ketchup
14,553
248
When I first read that, the card reader jumped out at me as something to disconnect. I know others have given you things to try as well.
VirtualLarry
56,542
10,167
I missed that. I had similar problems one time with a rig that I built, using a USB2.0 multi-card 3.5" bay reader. Would get "not responding" error, if I remember correctly. Also had issues booting properly. Turned out, I was using a cheap case-included PSU, and it had damaged the mobo's USB ports, causing issues with the card reader. Or perhaps the card reader was just bad to start with, but I eventually couldn't even boot the system until I replaced the PSU, but after I did that, I still had issues with USB devices on that rig.
Pleasehelp
31
Nope. Care reader is relitivly new. Computer froze before the thing was ever installed too.
