cmdrdredd
Originally posted by: akshayt
If you actually wanna know, Xbox 360 uses ATi R 5xx series and is surely better than any 7600GT/7800GT class card out there.
To be more precise, it is better than any current graphic card but does loose to dual GPU setups.
The place where PCs take the lead is that they are equipped with much faster CPUs and a fast CPU like the C2D paired with a 1900XT beats the Xbox 360!
Actually I don't think it's quite that simple. It is based on an off the shelf GPU, but has some specific instructions that a standard PC card doesn't have available. the raw power is far less than a 7900gtx or x1900xtx/1950xtx
