Question Pc does not Show display
ASIFali1100
When i turn on my pc cpu fan turns On and Case fase on but no Display and when i hold power button the blue lights blink but does not shutdown after turning on around 5 min and i unplugg my power cables and put back again it turns on the screen cames whats the problem iam facing this issue every time when i turn on my pc if display come then i press power button it work on shutdown but when i start it blinks lights and dows not shutdown
MY BUILD
Ryzen 5 3600
A520 s2h
Asus Rx 6600
Ram 16 gb 3200mhz Corsair
Samsung 980 Evo 1tb M.2
Tb hdd
Psu thermaltake toughpower 750 80 plus Gold
Is the display cable plugged into the mobo or the GPU?
Is the system DDR 5 for ram?
Do you have the build specs of pieces listed in PCPartPicker.com?
My first thought would be power supply. Anytime I hear "fans spin up, but no post" I think power supply. It may be your motherboard, but if you have a spare PSU I'd swap it out and see if your rig boots up. Then I'd move to the motherboard as the culprit. Try clearing the UEFI (bios) back to default settings. Did you try reseating your video card? Did you check your video cables?
Do you have one of these plugged in?
It might emit a sequence of beeps that might point you in the right direction.
I change my psu bought New One same Problem Reset Bios set to deafault same problem bought new dp cable for gpu same problem
1. do you have the proper 6 pin power cable plugged onto the GPU?
2. do you post anything when you turn on? like you see the motherboard logo followed by a press delete to enter bios?
3. (sort of dumb question) Is your monitor set on Displayport?
4. If you can not even post... you have a problem with a core hardware... (CPU / MEMORY / GPU / MOTHERBOARD)
