Question PC Case Help
fastamdman
1,335
70
Hey guys I hate making posts but I simply can't decide on a case.
Thinks that I am looking for, in order are as follows.
Minimum of 1 USB Type C on front panel
Airflow
Dust Filters
Tempered Glass
Sound at reasonable levels
RGB is the least of my concerns.
I don't really have a budget, so feel free to recommend anything and give me some pros and cons. I've read a ton of reviews and I'm ready to buy, but unfortunately I'm just not leaning towards anything yet.
LOUISSSSS
8,771
58
very nice, hope things r working well!
If you don't mind some critiquing: too much light for my taste, and def not sure why 3x sideways intake/exhaust fans are needed. Also, anywhere to put those 2x 2.5 SSD?s the Lancool has them being the MB so they dont disturb the front view with a dark color on white case. Lastly, those black PCI E slot covers look out of place.
Heres a recent pic before i cleaned up that PSU cable on my Lancool 2 build
fastamdman
1,335
70
The case really isn't nearly as bright as the pictures make it out to be, I'm very happy with the lighting. Considering I am only running 2 radiator fans, for cooling and aesthetics I feel like it looks the best having all 3 120s on the side. I plan on moving the SSD's to the rear when I install the other 3 120 corsair ML's on the bottom.
Still debating if I want to change the radiator fans or not though.
