Question PC build not working properly
Nitorus
Hello,
I’d like to ask about my PC problem. I bought a new GPU RTX2070s. CPU that I use is AMD Ryzen 5 2600 and 16GB of RAM Memory 3200mhz (locked on 2966 cuz my MB doesn’t allow me to use full speed). My fps in csgo didn’t really change (150-250) even tho one guy who has almost the same hardware as me has 400fps. While playing BF5 on low settings I am having problems with low fps that I didn’t use to have before the new GPU, but atm it’s sometimes really hard to even play the game. I’ve tried to set up some things to boost my PC, but it didn’t work out for me. While playing BF5 my cpu runs at 95%~ and the same goes for the gpu (max GPU temperature I’ve seen was about 60-65 degrees C). I would really appreciate any kind of help or tips. Thanks a lot.
Muadib
18,127
912
The RTX2070 isn't new, and hasn't been for some time. Is there a reason why you didn't get a 3000 series card?
In2Photos
2,626
2,794
What resolution do you play at? CSGO is typically a very easy title to get decent fps. BF5 is a bit tougher. What GPU did you have before the 2070?
DAPUNISHER
32,488
33,586
You haven't provided enough info.
Have you used DDU to remove previous drivers and start fresh? Have you checked it with GPU-Z? This is a used card? When is the last time the CPU was repasted? Pre-built system or DIY? What power supply are you using?
mikeymikec
21,634
16,908
Hello,
Can you be specific about what "low fps" means in your opinion? You started by complaining about 150-250fps.
Was it BF5 that spurred you to change graphics cards? If so, what were the frame rates you were getting?
Nitorus
I am still a student and I don't really have too much money.
Nitorus
I used gtx750Ti, so I changed GPU so I could play all the new games. I had about 60-70fps in BF5 and now I am having problem to get to these fps. And I am complaining about 150fps in CSGO cuz I want to buy new monitor, so I´d like to have atleast stable 300fps.
