1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
General net surfing, playing music, running squeeze boxes. No gaming. No blu ray watching.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
I have monitor, case, and cd drives already. Budget for the rest in the 500 to 750 range.
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
No preference.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Case, CD Drives, Monitor, Keyboard, Mouse.
6. IF YOU have searched and/or read similar threads.
Nope
7. IF YOU plan on overclocking or run the system at default speeds.
Default
8. What resolution YOU plan on gaming with.
No gaming.
9. WHEN do you plan to build it?
ASAP
USA
No preference.
Nope
Default
No gaming.
ASAP
