PC 3d $1800 videocard and monitor
davide445
For the design studio I'm working with we want to purchase a new PC, to be used with Adobe Illustrator, InDesign, Rhino3d, KeyShot, VRay.
Base config is Ryzen 5 1600, 16GB RAM, 275GB SSD, 1TB HDD, 550W PSU
For the video card and monitor this is current choice:
Video Card: Gigabyte - GeForce GTX 1070 8GB Windforce OC Video Card
Monitor: BenQ - GW2765HT 27.0" 2560x1440 60Hz Monitor
Doubt if I really need a GTX 1070 or 1060 will be enough. Also for the monitor I was considering
Monitor: Asus - MX239H 23.0" 1920x1080 Monitor
Monitor: Dell - SE2717H 27.0" 1920x1080 75Hz Monitor
Not sure if make sense a FullHD for 27" or will be better a 23" for that resolution.
The decision is whether:
1) The programs you use can be accelerated by a GPU - maybe someone knows or OP can research.
and 2) If yes to #1 whether a faster GPU is worth considerably more than a normal one.
3) If either of #1 or #2 are "no" then I would find the biggest and highest resolution good quality monitor I could fit into the budget.
Finding out #1 is most important; and sorry if I missed something.
For #2 sometimes slow GPU acceleration is many times faster than only a CPU, but a much more powerful GPU only doubles the performance of a slow one. So a less powerful GPU and saving a few $ could be a good compromise if it means you can grab a much larger and higher resolution monitor.
Thanks @richaron
Adobe Suite: OpenGL and CUDA/OpenCL
Rhino3d: OpenGL
KeyShot: OpenGL
VRay (for Rhino3d): CUDA accelerated
so all of them are GPU accelerated for compute or realtime graphics. I need to research the performances of 1060/1070 in the specific packages.
For OpenGL/DX/Vulkan I was reading 1060 as a FullHD max quality graphics and 1070 best for QHD, just want to know first hand experience.
Looking at local reseller this is my current conf
CPU AMD Ryzen 6 1600 6-Core (Hexa Core) CPU 3.40GHz
MOBO MSI B350 TOMAHAWK AM4 ATX
RAM CORSAIR Venegance LPX Series 16GB DDR4-2400 Kit CL14 Black
Videocard GAINWARD GeForce GTX1070 Enthusiast 8GB
Hard disk SSD CRUCIAL MX300 275GB SATA 6.0 Gb/s 530 MB/sec
Hard disk TOSHIBA P300 1TB 7200rpm SATA III 6 GBit/s
Pc Tower FRACTAL DESIGN Define R5 Black Edition
PSU CORSAIR RM550X 550Watt 80 PLUS Gold
Monitor LED AOC Q2781PQ 16:9 4ms 2560x1440
In doubt if I need to invest more on CPU with Ryzen 1700 and less on GPU with GTX 1060
Refined configuration pushing more on CPU for traditional rendering
CPU AMD Ryzen 7 1700 8-Core (Octa Core) CPU 3.00GHz, with fan
282,50EUR
MOBO MSI X370 Gaming PLUS ATX DDR4-3200 109,50EUR
RAM G.SKILL FlareX 16GB DDR4 KIT 3200 CL14 2x8GB Black 215,90EUR
Videocard KFA2 GeForce GTX1060 OC 6GB 302,90EUR
Hard disk SSD CRUCIAL MX300 275GB SATA 6.0 Gb/s 530 MB/sec 85,50EUR
Hard disk TOSHIBA P300 1TB 7200rpm SATA III 6 GBit/s 48,50EUR
Pc Tower FRACTAL DESIGN Define R5 Black Edition 104,50EUR
PSU CORSAIR RM650X 650Watt 80 PLUS Gold 90,90EUR
Monitor LED AOC Q2781PQ 16:9 4ms 2560x1440 353,50EUR
Total:1.594,10EUR
I will probably OC the Ryzen to 3.5Ghz on standard fan and thermal paste, upgraded to 650w PSU for future dual GPU conf, changed RAM for certified with mobo e specific for Ryzen.
