- May 20, 2010
- 4,020
- 1
- 81
What's this?
The front of my exhaust, and the support for my radiator both rusted out. Both needed to be replaced at the same time to make the car safety inspect-able.
What's this?
Believe me I've learned my lesson on this one, and will never make the same error again, but this is still the situation I need to deal with.
I am thinking for my next car I will go one of 2 ways:
1) Buy something new (or nearly new) with a good warranty.
2) Buy something really cheap in cash so I don't need to care if its a POS and I can just get rid of it.
Unfortunately I wont have that opportunity for a while...
how many miles have you put on it yourself?
If you're buying a reliable new vehicle, you really don't need to spend extra money on warranties. Most of them are just a scam.
Just buy a good new vehicle and follow its routine service schedule.
My advice would be to decide which new vehicle you would buy, then look for a used version of the previous year or something with like 30K miles on it. Will be cheaper, and almost as good as new.
You're problem is you overpaid for a beater. Nothing wrong with shelling out 10-15K on a used car, but get one that is low mileage and has been proven to be a reliable car.
I totally agree that I way overpaid. Thanks for some good advice and not just raining down judgment like some other people around here![]()
With all due respect -
After posting a situation like that you have to expect some ribbing and flaming. Nothing anybody posts is going to screw you worse than you screwed yourself.
Just take it in stride.
You can get trapped with a new car too. Collision insurance will be more expensive, and even if you get into an accident, it won't cover your loan, just the value of the car. I have a friend that bought a new car (Hyundai), and got rear ended about a year later. The car was totaled and she was $8000 upside-down. So $8k in the hole and she didn't even have a car to drive.
I think the best thing to do is just buy less than what you think you can afford.
You're going to the wrong mechanic dude. You need to find one of those mechanics that inspects anything that can successfully drive into a garage and turn on its headlights. When a place says "you need your exhaust replaced or we can't inspect this" I drive my car somewhere else! That exhaust that needed to be replaced has been inspected 3 times since then.
If I fixed all the shit those stupid quick lube places said were wrong with my junker, I'd be fucking bankrupt. And yet, the car is still on the road...sure it smells awful sometimes but its not like I was trying to pull ass with it.
People down in the south and California can make their old heaps last forever. But your average 10 year old car from the tundra is already dying of salt cancer and had its suspension destroyed driving over frost heaves and pot holes. Gimp it along if you can for cheap, otherwise cut your losses and move on. God I hate cars. (On a side note, I'm looking into grease undercoating if I get a new car...no one does it up here but if it worked boy would it be worth it)
I don't think you can do much but just buy your way out of this one at this point. You got taken all over the place.
That's why you get gap insurance. worst case you're just without a car and not owing a shit ton of money on something you don't have.
As it just so happens I have the exact breakdown!
Oil Change/Exhaust Patch $121.97
Battery + Installation $107.33
Rear Brakes $795.92
Spark Plugs $67.77
AC Compressor $1,385.05
Exaust Patch $169.19
Spark Plug Installation $99.61
CV Boots/Sway Bar Links $569.95
Left Lower Control Arm $142.26
Left Lower Control Arm Installation $189.44
Tokico HR2 Struts $513.83
Shock/Strut Install and Alignment $393.24
Brembo Blank Breaks $475.65
Rad support + Front Exhaust $2,311.47
Right Front Axel + Install $350.75
Tow + Starter motor & install $451.29
I'm not a mechanical guy so I have to pay out the ass for labor.
Let me get this straight you're paying $320 a month for a $6000 car. And you've had the car for ~2 years, which would mean you've paid ~$7680 for it so far, and have another 18 months, which would be an additional $5760. How fucking stupid are you? paying ~$13440 over 4 years for a 10 year old car worth less than 1/2 that. This can't be real...
Well, look on the bright side.. at least you have essentially a brand new car, now.
You can't count things like brakes and spark plugs. Those are maintenance wear items that you will have to pay for on any car. I don't see any big problems here, except 2.3k for a radiator support and "front exhaust". I'm not sure exactly what was repaired, but that seems a little outrageous.
Keep in mind he bought unemployment insurance (ripoff) and an engine warranty (probably cost about $2K) and his interest rate is probably over 10% by the sounds of it.
It's not that one particular job has been overly expensive other than the AC and the exhaust/rad support job, but when things break month after month its hard to get ahead.
You need to find a new mechanic. Sounds like you're taking it into a big dealership type repair shop. Find a qualified, private mechanic who will do the work for 1/2 of what you're paying.
I would not want to pay all that interest. I would be making massive payments to pay the loan off early.
Have you been paying extra each month? I would have been doing that with such a loan.
