AMD has also put dual core Opterons in the hands of the motherboard vendors. While we couldn't get a confirmation of clock speeds, the motherboard manufacturers we talked to could not say the same for Intel. It seems that AMD is truly ahead of Intel when it comes to dual core.
Originally posted by: clarkey01
"Intel says they could have made 4.0 Ghrtz but didn't. What the heck does that mean? LOL "
They could have but it would of taken another stepping for prescott and I have no idea what the power consumtion on that would be , im sure a 3.6 E uses 115 watts.
It uses 210 watts, the 115 is the thermal waste by-product. The new 90nm Athlon64 uses 115, and about 50 is heat. Big difference.......Originally posted by: clarkey01
Read the front page JiffyOriginally posted by: jiffylube1024
Holy sh!t, is this right? 210W peak on the 3.6E?
Originally posted by: LTC8K6
Why are you guys trying to say that the power used by the whole computer is the power used by the cpu alone?
The election is over, no need for any more propaganda.
Now logically it follows that if Anand did a good job isolating the load to the CPU subsystem that the increased power draw for each system was created by the CPU's power demands. Now since Anand is a bad cat and all that I trust his testing methodology, so I need only check the chart to see the 560 is drawing considerably more power than the FX55, and the difference between the 530 and 3500+ is :shocked:We measured power consumption in two states: idle sitting at the Windows desktop and under load while running our Windows Media Encoder 9 test, which proved to be one of the most strenuous CPU tests we ran as it pretty much isolated the CPU subsystem.
Sorry, I was answering YOUR question about power utilization......Originally posted by: clarkey01
kinda gone off topic here
Linked !!!! At full load, uses 210 watts !
P4's use more power than A64's?
Gee, I didn't know that! I'm glad those total system power graphs let us know that, otherwise we'd be wondering why P4's are hotter than A64's.
But not too much hotter Link!
That link is BS. Of course Prescot owners are going to be positive. I only trust a reliable review site.... Like Anandtech.
Thats cause they throttle when they get too hot equal less performance.
The 3.6 presshot uses 150W under ful bore accroding to intels own specs !!! (not TDP which is really BSP)
http://www.cpuheat.wz.cz/html/IntelPowerConsumption.htm
