Originally posted by: KeypoX
but what about if you only have 2 hds? and one is kinda small
Well, the expression 'living beyond your means' comes into play here.
It's a case of how important is your data, if one hard disk is 'kinda small' then you maybe should think about how much data you can actually possess at any given time. If you don't have enough space to back it up onto a separate disk, the question then is are you prepared to lose all your stuff? Because that's a potential scenario. So if I had a 120 Gig disk with 30 Gig and 90 Gig partitions, but only had a 40 Gig second disk, the maximum amount of data I can safely own is 40 Gig, anything more I'd have to be prepared to lose.
Everything I and a lot of other people have said here is based on the 'what if' question. People who think their data is safe because it's on a separate partition than their OS are rather misguided. Their data is really no safer than if it was on the same partition as the OS, because it's still part of the same 'pie'. The only thing it protects against is accidental deletion while formatting, not hardware failure.
If you have a second disk that is 'kinda small', the most sensible thing to do would be to backup to DVD.
Partitions and data loss are often not far away from one another. The reason I discourage people to not rely so much on partitioning these days is because of having witnessed unfortunate situations where partition tables have been hosed, or some 3rd party partitioning app has taken a dump on you. PM has done this to numerous folks, despite lots of people recommending it.
The only reason I have 2 partitions on this 320Gig disk is so that OS reinstallation is simpler, i.e. I don't have to back up loads of stuff before a reinstall.
It has nothing to do with data being safe. Nothing whatsoever. It has everything to do with convenience.
I do not back up to DVD, maybe I should. But the reason for that is that I have another 6 disks that only ever go into an enclosure and are offline 99% of the time. They are rarely exposed to the Internet and their lifespan is increased as they are not spinning anywhere near as often, just enough to see that they still operate. To me, the chances of me losing the stuff on the 2nd partition as well as that on the 3 out of 6 backup hard drives is rather remote.
But I still think I should start to make a few DVDs. Something to consider.
And I should stress that the points I and others are making are not to shoot other people down, but merely to wise them up.
