EXCellR8
I've been mostly happy using my current 34" panel (Acer XR341CK) for the past 5 years, but was considering an upgrade before Big Navi is released. The current IPS panel only goes up to 75hz (OC'ing nixes the FSync) and I'd like to venture upward into the 100+ hz range. I don't think I'd need to go bigger in terms of physical screen dimensions, nor would I want to downscale my current resolution, unless there was some obvious incentive to do so.
Here's the criteria:
- at least 100hz
- FreeSync capable
- IPS preferred over VA
- flexible on brand (so long warranty is decent)
- 21:9 is preferred (2K is fine)
- at least 2x USB 3.0 ports
- HDMI & DisplayPort w/ miniDP
- hAS maD GAm3R fLa1r y0!!!
As a side note, I'm still undecided on whether or not I would jump into the gaming console arena later this year; without the need to upgrade my TV I should have some funds to play around with for PC goodies. Having said that I'd like to keep it under $1,000...
Any and all recommendations are appreciated. Thank you!
- at least 100hz
- FreeSync capable
