Panaflo 80mm 21db - $3.19 or 10/$26.50
najames
393
I ordered 6 Speeze case fans (80mm) from Newegg, maybe not as quiet, but they have both 3 and 4 pin plugs. I ordered 6 and they came out to $1.29 each. They also automatically cut shipping back from $4.99 each. Under $20 for 6 fans shipped doesn't seem too bad.
http://www.newegg.com/app/View...=35-150-007&depa=0
From my order....
FAN COOLINGFAN SPEEZE FD08025S1M4 N82E16835150007 6 $7.74
[35-150-007] Has Volume Discount! N82E168COM 1 $.00
Subtotal $7.74
Tax $.00
Shipping and Handling $11.94
Total $19.68
Interitus
2,143
9
I've ordered from BG several times. I've received both China and Japan models.
The Japan's are definitely higher quality as reported here. They have a 2 pin plug and no RPM sensing, however an Xacto knife to cut off the 2-pin guide will make it fit fine on 3 pin connectors.
BTW for silent enthusiasts, that Silverstone fan won't hold a candle to the Panaflo. Even the Chinese version.
bgbysleepy
58
so this panaflo at $3.19 has only 2 pins. and bgmicro sells PWR1204 4-Pin Panaflo Fan Tail for $1.49. If i want to buy 7 fans, i have to buy 7 fans + 7 four pin?
mdetz
570
No. You don't have to get the 4 pin tail.
try to visualize:
normal 3 pin:
this fan
make it look like this:
and it will fit.
amdskip
22,530
13
bgbysleepy, these fans will plug directly into your motherboard if you have fan headers open. They require one little snip of the connector but it is very simple to do.
Slickone
6,120
Originally posted by: Melectricus
These fans are QUIET not SILENT for those who are particular. I have used the fans to replace PSU 80mm's and it makes a major difference on cheaper PSU's. As for case fans, I have two computers with twin front and rear fans that I retrofitted with these and I like them but they are not silent. I now use a fan controller and control 2-fans per channel, the 'bearing' noise is audible at slower rpm, more than the NMB's I used to get from bestbyte, but I can't find them as cheap anymore.
Is that because these are from China? Normally everyone says the L1A's are about the quietest out there.
And even making the Panaflo 2 pin into a 3 pin, you'd have to have a fan controller that uses 3 pin connectors, right? You wouldn't want to power them w/ the mobo connector.?
I don't guess you can request Japanaflos? :)
Wouldn't a 9 blade fan be quieter than one with 7 larger blades like the Speeze Masscool mentioned above (at the same speed)? In aircraft, more blades = quieter.
BTW, the Masscool ends up $.99/fan incl. shipping for me, + tax :( if I order 15. Anyone else use them?
rameshms
46
Isn't the 3rd in the connector meant for a reason ? AFAIK, it is for reporting RPM of the fan. If BIOS were to monitor the fan rpm (i'm considering this for my cpu fan), it would be critical.
Also, aren't ball bearing fans superior to sleeve bearing ones such the panaflo ?
:confused:
mdetz
570
:confused:
99% of panaflo's you will find do not support RPM monitoring.
and ball bearings last longer than sleeves, but sleeves are quieter. But the use the "Hydro Wave" sleeve, which is its claim to quietness, and is supposed to last longer than conventional sleeves.
tr1kstanc3
361
i replaced 4 system fans in my main box with these panaflos. originally had the coolermaster ballbearing fans rated at 25db. these chinaflos blow the coolermasters away. before my computer sounded like a small private jet under my desk, now i can hear my ionizer over the computer.
yeah im satisfied, great deal!
imported_Snagle
1,805
how long do these guys take to ship? Im in MN and I ordered sunday night, just wondering when I should expect them.
mdetz
570
I think he's out of TX (so am I). I've gotten in 2 day orders & 2 week orders.
amdskip
22,530
13
I ordered a case of 100 when I purchased mine. I think it took 5 days to get to me because they shipped via UPS.
ss284
From my order....
Subtotal $7.74
Tax $.00
Total $19.68
You could have ordered 15 fans and gotten them for less than what you paid...
-Steve
uOpt
1,628
I have a bunch of L1A. I couldn't hear them, even when out of the computer case held by my ear (with the computer running in the background).
Note that the panaflo come in "L" and "H" versions, with the "L" ones being the quiet ones and the "H" having more throughput.
I ordered some 12L 24CFM which are supposed to be the same as the L1A. If somebody wants me to post a comparision, P.M. a reminder in a few days.
uOpt
1,628
Hm, bgmicro.com shopping cart doesn't work right for me.
Randomly drops my items. Too bad, would have ordered the 10-pack...
3point14
1,843
Excuse my ignorance, but do these run off of 3v or 5v? I would like to use these in a stereo cabinet to cool down a receiver, cable box, dvd player, etc. and I need to connect them to AC instead of DC. Also, if anyone has any suggestions on the easiest way to convert these DC fans to run off of AC, please PM me :)
JohnDoh
359
Anyone email yet and confirm if these are chinaflos or japflos, or will they not guarentee what they are?
From the people at http://www.silentpcreview.com/index.php they say this is one the best fans you can buy period. Also that the japflos are superior and between all the (I use this term lightly) anal members and staff, theyve probably seen 10,000 panaflos.
Responce to 3point14... 12v unless you want it to spin slower 5v work fine but I dont know about 3v... but not a direct from the psu line except 12v
Interitus
2,143
9
You'll get Chinese versions. If you want a guaranteed Japanese, they're $5.99 each at Jab-tech.
mdetz
570
Says in product description. 12 volt DC.
you needFAN1042
Or a converter, or a DC power supply.
You can just crack open your HTPC (you have one right?) and run the fans off of your P/S.
cyberfuzz
427
From my order....
Subtotal $7.74
Tax $.00
Total $19.68
guess you didnt realize that if you bought 15 the total would have been 14.84 shipped? way to order half as many fans and pay an extra 5 bux ;)
bjamm2
742
From my order....
Subtotal $7.74
Tax $.00
Total $19.68
lmfao
