Um, I just plugged the fan (on my PAL6035) into the CPU fan power socket (near the voltage jumpers - see your manual). This is assuming the fan has the standard 3-pin connector; if not, you may need to buy some kind of adapter. You should really check the manual about this kind of stuff if you have questions... either that, or be more specific about your question.
